Results 1 to 8 of 8
    Two_wheels
    Nov 2007
    2.1 or 2.35 Nevegals on '03 Enduro?
    Hi all,
    I'm looking for suggestions on whether 2.1 or 2.35 Nevegals would be a better bet on an '03 Enduro.
    Thanks,
    D
    Reputation: Goose Ryder's Avatar
    depends on how you ride and what your looking to do. I dont mind the weight so I have 2.6 in front and 2.35 in rear, but i like to jump and ride some real tech. down hill stuff.
    Reputation: tonys102's Avatar
    I would agree, I ride 2.1 on my Stumpy, but then I am not too hard on my machine, sort of AM lite..
    Building: ​Boardman 2010 HT Pro
    Current Joy: '11 Giant Anthem X
    Previous Joy: '09 Commencal Meta 5 VIP
    Two_wheels
    Nov 2007
    Thanks Goose Ryder. Riding-wise, this is for having fun in the snow. I'd go for the 2.35s, but I wonder if the 2.35 'll fit in the back. Sounds like that's not a problem.
    Dérick
    Two_wheels
    Nov 2007
    Thanks Tonys102. Riding in snow and some rocky stuff, but AM lite too.
    Dérick
    When I go to the ski lifts I try to run the same size all the way around. I have a kenda kenetic 2.6 for the front and rear when shuttling. I took a digital caliper and measured the tire when on the rim and it measured only 2.4. It is really close to the tire when in the lowest front chain ring so I would say for riding around the largest you should go is a true 2.35. If your going to the mountians for down hill and will never touch the small chain ring I would say you would be safe with 2.5, but it is close check for fitment before heading out.
    Regards,
    Two_wheels
    Nov 2007
    Thanks man. I'll stick-E with the 2.35s...
    D
    I like to run the stick-E up front, and DTC in the back. The DTC's don't wear quite as fast.
