Results 1 to 6 of 6
Thread: 142+ spacing
    Reputation: BoiseBoy's Avatar
    Feb 2006
    142+ spacing
    I know that it has been discussed before, but I couldn't seem to find what I was looking for with the search function.
    I have a set of Roval Control SL wheels and they are the 142+ spacing for my Epic.
    I was wondering if it is possible to use the "plus" wheels on a standard frame with 142 spacing? I know that it would push it out the 2mm, but is there a spacer or something that can be changed to make them a straight 142 wheelset?
    The other question: Is it possible to change the axle on the front to fit the standard 9mm quick release into a 15QR fork?
    BoiseBoy
    Reputation: Biking Brazilian's Avatar
    Feb 2006
    Thanks for the reply.
    From the diagram it looks like the 142+ cannot be altered to fit another frame.
    Once 142+, always 142+, which seems to limit the Roval's application on different frames/bikes
    BoiseBoy
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    142+ wheels do technically fit standard 142, but the cassette lockring rubbed the frame on the bike we tried them on.
    The Roval should convert to 15qr no problem. You just need to order the proper endcaps for the wheels.
    14 Aurum, 16 Fuse, 17 T130
    I have heard that 142+ may or may not work in a standard 142 frame. Just depends on how tight it is and if you have the clearance. Just like the compatibility guide shows, there are not 135 end caps to put on 142+ hubs.
    There are Roval Control SL endcaps that do 9mm QR or 15QR. I have both. Right now I am running the 15mm endcaps with a DT swiss 9mm RWS thru-bolt using a 15mm to 9mm thru-bolt adapter I got on ebay.
    Mountain Bike 15mm thru Axle to 9mm Quick Release Wheel Adapter | eBay
    old fart
    not supposed to work, but will in certain circumstances. depending on the target frame and the clearance between the cassette and the stays.
  1. Replies: 6
    Last Post: 07-11-2013, 07:18 PM
  2. BMX hub spacing?
    By gratefulbiker in forum Singlespeed
    Last Post: 05-09-2012, 02:08 PM
  3. 135 to 142 hub spacing???
    By bcinlas4 in forum Bike and Frame discussion
    Last Post: 03-04-2012, 10:10 PM
  4. 2007 fox 40 spacing help
    By Moosey in forum Downhill - Freeride
    Last Post: 06-10-2011, 04:07 PM
  5. ABP Spacing
    By chowdownca in forum Gary Fisher
    Last Post: 03-03-2011, 12:36 PM
