Results 1 to 38 of 38
    Rider
    142+ Explained Graphically
    This made it easier for me to understand the new "standard"
    Attached Thumbnails Attached Thumbnails 142+ Explained Graphically-142plusexplained.jpg
    How much do you think one would be able to get for a never used Specialized 142+ rear hub? I'm looking to get rid of the one one that came on my S-Works.
    Reputation: abbeytrails's Avatar
    Quote Originally Posted by erichwic
    I'll start the bidding at 1 case of beer!
    Rider
    Pm sent
    Dec 2005
    Anyone know if the '11 SX Trail 2 runs this hub? Can a Hope Pro 2 be converted, or a Chris King????
    It says 142 on the specs but doesn't specify the "+" which is key.
    Reputation: goneskiian's Avatar
    Sep 2004
    Just as we suspected. To swap between a 142 and a 142+ hub will require derailleur adjustment.
    Ugh. Specialized really needs to step up and offer the DT internals hub for sale.
    For those (tls36) that haven't seen this here is the info page at Syntace who developed this standard.
    http://www.syntace.com/index.cfm?pid=1&pk=1314
    Scroll down for a list of compatible hubs.
    Short answer - Yes Hope Pro 2 and Chris King can be converted.
    I'm going to wager that the SX Trail is a standard 142 and NOT the Specialized proprietary 142+.
    Cheers!
    P.S. Huge THANK YOU to Epic29er for posting this great illustration of what this new standard really means and what Specialized has done with it to be a real pain in our ass.
    I'm not even going to use Specialized hubs, so it looks like the standard 142 will work for me. Don't want to deal with the derailleur adjustment. That is disappointing because I'd love to get a set of the carbon Roval's for a race set-up but due to the required adjustment, I'll be getting a few sets of Stans.
    Now broadcasting from CO
    Reputation: PAmtbiker's Avatar
    Feb 2005
    Sort of OT, but I wonder why Spec. says that it's 142+ hubs wouldn't fit any other 142x12 frames... to my non-engineering educated eye, I can't see why they wouldn't work.
    Brought to you by rocks.
    Reputation: GTR2ebike's Avatar
    May 2010
    Quote Originally Posted by PAmtbiker
    My guess would be the 2mm that the cassette is spaced could cause some rubbing.
    Sep 2004
    Quote Originally Posted by GTR2ebike
    I can see that. They probably designed some extra clearance for the chain in the small cog.
    Then again, I can't see why it wouldn't work. Certainly worth a try.
    Reputation: yxan's Avatar
    also anyone ever see or read about the new 135mm standard? upon inspecting the roval 135 carbon rim it looks like it is using the "new 135" anyone ever see this wheel in the flesh?
    Rider
    yxan,
    The picture at the top of the thread has both 135 standards.
    question for the experts? can you put 135 (5mm QR) end caps on the 142+ hub negating the x12 standard? I wonder cause for single speed hardtail this would be pretty sweet. more triangle in hub, and really cassette spacing on a single speed is irrelevant
    Quote Originally Posted by goneskiian
    I believe the Hope Pro 2 adapter is available now. When I talked to King back in November though, they told me it would be mid-summer before the King 142mm adapter kit would be available.
    I'd love to know how much of a difference the 2mm makes for wheel stiffness. When I talked to the guy at Specialized CS he made it sound like it would be a dramatic improvement. I personally find that a little hard to believe. I'm sure that it is incrementally better, but I'm not sure that I'd be able to tell the difference personally, especially when I'm using Crest rims which aren't going to be the stiffest to begin with.
    Granted, I have the 142+ hub (non DT internals) at home and I'm not spending the $$ to build it up - guess I'm not that curious...
    Oct 2007
    Quote Originally Posted by TurnerConvert
    Turner, I'll let you know how they are. I have a crest rim sitting in the garage that I'll be built up on my 142+ hub. I will have the crest set of 142+ and the 142+ carbons. I converted a set of ztr crest wheels to 142 for my sister and will do a head to head comparison between the two on the same trail with the same tire/pressure. Only problem is we just got 21"+ of snow yesterday and the test may take a while.
    just ride
    Reputation: 24hrsordie's Avatar
    Quote Originally Posted by yxan
    i tried swapping out the end caps between my roval carbon 29ers and the aluminum roval 29ers both use the dtswiss internals... i could not get it to work, if anyone gets this to work, please let me know
    on another note I have converted the roval aluminum 29ers that use the dtswiss internals to 142 with the dtswiss conversion kit
    Reputation: cru_jones's Avatar
    So, is a rear 142+ wheel convertable to fit into a standard, 135mm frame? Easily?
    I ask, because I'm looking at getting a new Epic, but the models I'm looking at (non S-works) come with the 142+, but I'll be using a lighter wheelset and won't have any use for the stock wheels (therefore I would like to sell them).
    Quote Originally Posted by cru_jones
    It really depends on the wheel. The conversion from 142mm to 135mm requires a different axle for the hubs that I have seen. Most hub manufacturers seem to be offering the conversion (I9, Hope, King sometime this year, DT Swiss) - I'm guessing there are more, but these are the ones that I was specifically researching a few years ago.
    Why does S even bother with a 142+????? I mean does it REALLY make a big difference for the bikes or riders that these 142+ are put on??? C'mon S, you guys are over engineering!
    except change 29er's
    My I9's converted no problem new shaft and caps. I guess there's a reason why they cost alot at first. It wasn't even that expensive for the shaft and caps.....To bad they clash a little on color. Green spokes with brown hub on a flow yellow frame.. I'll have to go all brown when I have to money for some new spokes...
    My issue is that I want an Epic 29er (either the Expert or Evo R), but I want to upgrade to either the cabon Rovals or Stans Podium MMX before even getting the bike.
    So can someone smarter than me explain what I should do, if the shop won't give me a decent credit (if any at all) for the stock wheelset?
    They will never be used, so I would want to sell them if not (to offset the cost of the upgrade), but I'm assuming the market would be very slim given the 142+ style rear hub, correct?
    Quote Originally Posted by chauzie
    AccordIng to the clearly unbiased individual that I spoke with at S customer service, the '+' makes a significant difference....
    damn right! significant difference in the revenue stream!
    You know it's ridiculous marketing to the Nth degree when we have XC riders having to pick their brains out between 135, 142, 142+! What's next? 149.3+???
    Wasn't it only a few years ago that dh bike rear axel were 135?? So I guess today according to S, an Epic rider has progressed to dh level now. Damn S marketing! haha
    Well I had the new 142 rear axle and end caps installed on my DT 240 and the rotor/caliper and not lining up......about 3mm difference...for reference the brake is new xtr 985 and the rotor is RT76 6 Bolt Shimano....not sure what the fix is...
    I'm sure the new 142 hub will work perfectly...
    MCH Co-Captain
    Much appreciated. Not sure as to why it is not matching up. Really don't want to have so shim the rotor.....
    According to the "142+ Explained Graphically" thread, the disc side should line up the same as the 142+.
    MCH Co-Captain
    Right, but that document is speaking to Roval hubs only. You would think that a DT 240 135 hub coverted to 142 hub and a Roval 135 hub converted to 142 should fit into the bike exactly the same. Especially since that document references the DT Conversion kit. Perhaps Robert @ Masterlink can shed some light?
    Another fix would be a set of those Carbon Roval's but that would blow the budget completely!
    Mar 2005
    Not to mention that the are out of stock.
    I finally managed to convince myself to get a set for my Epic Expert, a little too late ;-(
    Reputation: lancelot's Avatar
    Has anyone on here converted a set of carbon 29" Roval 135 to 142? Is it just the end caps that are needed or a axle as well?
    Quote Originally Posted by santa_cruzer
    Got mine a month ago with my Carbon Comp. Worth the wait, you will love them.
    Great thread on the 142 vs 142+. I'd like to have 2 wheelsets that I can change out quickly. Does anyone know if it's possible to space or shim the cassette and carrier on a 142 wheel out 2mm (each) to make it compatible with a 142+ frame?
    May 2010
    I doubt you will be able too as the cassette lockring probably doesn't use much more than 2mm of threads to tighten.
    Maybe leaving away the lowest/smallest cog would make enough space to fit the lockring?
    Quote Originally Posted by GTR2ebike View Post
    Thanks...will the cassette carrier (not sure what it's called) be long enough if the cassette was spaced out? If so, do they make lock rings with deeper threads?
    Reputation: Enduro4710's Avatar
    Quote Originally Posted by erichwic View Post
    I doubt you'd sell a 142+ hub, because you need a Specialized 142+ frame to fit it. Other brands will fit a 142 hub but not a 142+
    2013 Specialized Endruo Expert Carbon
    old fart
    Quote Originally Posted by richardchen View Post
    No you can't. Actually I have a set of DT350 hubs with 142 rear that run a set of winter hoops for me. I find that the rear derailleur adjustment required is able to be done using the front adjustment. Basically painless in other words.
Members who have read this thread: 10
