Results 1 to 5 of 5
Thread: 142+ ???
    Feb 2010
    142+ ???
    What is 142+ on the stumpy evo? Can I use a standard 142x12 hub on a 2012 stumpy evo?
    Apr 2005
    Everything you will need to know is in this thread:
    Specialized 142+ rear hub
    Basically, you can use standard 142mm hubs, but you will need to adjust your rear derailleur to a more inward position. The cogs on the 142+ hubs are positioned slightly farther (2mm) out from the center of the hub.
    *EDIT*
    See this thread, too:
    142+ Explained Graphically
    Justin
    Salt Lake City
    2012 Specialized Stumpjumper FSR Comp 29
    2006 Specialized Allez Expert Double
    You can use any 142 hubs on Specialized frames but 142+ hubs will ONLY work on Specialized frames.
    MCH Co-Captain
    Feb 2010
    OK, thanks for the help guys. I actually tried to search 142+ on here and google but couldn't find those threads.
    Dec 2004
    that's more specialized proprietary crap; makes it aggravating to own a specialized sometimes. . .
Hot Deals
Contests
Latest Mountain Bike Articles
