142+ ???
Printable View
  • 01-20-2013
    WHALENARD
    142+ ???
    What is 142+ on the stumpy evo? Can I use a standard 142x12 hub on a 2012 stumpy evo?
  • 01-20-2013
    authalic
    Everything you will need to know is in this thread:
    http://forums.mtbr.com/specialized/s...ub-679462.html
    Basically, you can use standard 142mm hubs, but you will need to adjust your rear derailleur to a more inward position. The cogs on the 142+ hubs are positioned slightly farther (2mm) out from the center of the hub.
    *EDIT*
    See this thread, too:
    http://forums.mtbr.com/specialized/1...ly-681526.html
  • 01-21-2013
    erichwic
    You can use any 142 hubs on Specialized frames but 142+ hubs will ONLY work on Specialized frames.
  • 01-21-2013
    WHALENARD
    OK, thanks for the help guys. I actually tried to search 142+ on here and google but couldn't find those threads.
  • 01-27-2013
    Mowerman
    that's more specialized proprietary crap; makes it aggravating to own a specialized sometimes. . .
