Results 1 to 7 of 7
Thread: 142+ to 142 hub
    Oct 2007
    142+ to 142 hub
    Anybody gone from a 142+ to a regular 142 hub? Did you notice any difference in stffness? Specialized says 10% increase in stiffness in the 142+but not sure I will feel the difference. I am a lightweighr rider.
    Want to get a lighter weight wheelset than what came on the bike.
    Feb 2006
    I noticed no difference in mine.
    old fart
    Simple physics would suggest that there would be a real difference, but it is going to depend upon the wheelset you have and their relative stiffness also. Put some Control SL's with 142+ on and you will notice a difference. I swap from alloy Haven's (142) to Control SL's and there is a big difference, as you'd expect, but impossible to isolate...
    Reputation: WR304's Avatar
    142+ to 142 hub
    The difference between a wheel built with 142+ and 142mm thru axle rear hubs isn't something I can notice whilst riding.
    A 142mm thru axle rear hub works fine in a Specialized frame so I'd go ahead and get the new wheels.
    Oct 2007
    Thank you for replies. The bike came with roval control 29 142+ (approx 1700g). I want to get a set of roval control SL carbon (1380g). The control SL carbon comes in both 142 and 142+. I think I will go with the 142 so if I change bikes I can still use the carbon wheels.
    Since the SL Carbons are expensive I wanted to be sure that I wouldn't notice a big difference.
    Can you convert the 142+ to a 142? Is it just a spacer?
    '14 Yeti SB95c--Pike'd
    old fart
    Quote Originally Posted by ds33gt View Post
    Short answer is no. Longer answer is that a 142+ wheel would work in a number of 142 frames, depending upon the clearance between the cassette and the stays, but certainly not guaranteed...
