Results 1 to 3 of 3
    Mar 2011
    110mm SID World Cup Brain
    Been told by Rock Shox that running a brain SID over 100mm can ruin the fork. They didn't elaborate on how or why but wondering if anyone else is running this setup and if you've had any issues?
    I Tried Them ALL... Moderator
    Reputation: Zachariah's Avatar
    My SID XX Dual Air runs 108mm and it still works beautifully. My only issue is the Xloc damper needs frequent seal replacement.
    "The mind will quit....well before the body does"
    Nov 2012
    They only make a brain in 80-100mm
    Specialized can do a "Brain Transplant" To put a brain in any reba or sid 80-100mm.
    But they will not put one in a 110 last i checked. Get your LBS to call specialized about the brain transplant and see if they will do it.
    2015 Epic Expert WC
    Sworks Phenom saddle, EC70 flat bars and seatpost, crankbrothers candy 3's
  1. Replies: 0
    Last Post: 05-09-2014, 10:58 AM
  2. Fox 110mm RLC?
    By pointerDixie214 in forum Shocks and Suspension
    Last Post: 08-27-2013, 07:23 AM
  3. Replies: 0
    Last Post: 05-23-2013, 04:15 PM
  4. RockShox SID 29 Brain vs the 2011 Reba with brain
    By Sawdaddy in forum Specialized
    Last Post: 01-28-2012, 02:38 PM
  5. 2009 brain vs. 2010 brain
    By hairyviking in forum Specialized
    Last Post: 01-11-2011, 11:17 PM
