Results 1 to 30 of 30
    Dec 2009
    '11 Epic comp 29er or '11 Stumpy fsr comp 29er
    Will soon be diving into the 29er world. Not sure if I should go with the Epic Comp or SJ fsr comp 29er. I like them both. Knowing that the suspensions are different on each bike I don't think that really matters to me. The Epic is about $400.00 more is it really worth it or not. The color choices on the Epic aren't the greatest but sometimes pictures don't do justice. Anyone seen either of these bikes in person maybe ridden them? and also not that it's important just curious what the weight difference may be.
    Reputation: 3034's Avatar
    Same old question just with 29r wheels.
    If you have to ask or arn't sure the answer has always been Stumpy
    Binned
    Nov 2008
    The Epic wil be up to a few pounds lighter and is better for going uphill. The Epic will seat you in a more upright position and it will be a stiffer ride. The SJ will be better suited for aggressive trail riding, it will seat you in a more relaxed position. It will have a cushy rider compared to the Epic.
    So, ask yourself these questions:
    Am I a fairly tame rider who likes fireroads and or smooth/flowing ST trails?
    Or, am I more of an aggro trail rider who likes to do drops and jumps?
    Answer: Epic, for the first question, SJ for the second question.
    You may want to play it safe and go with the SJ. It too will climb well, it just won't accelerate like the Epic will.
    Now, go out there, spend some cash, and lets see some pics!
    Reputation: dpastore22's Avatar
    As mentioned above, all about what type of rider you are!
    Dont sell the Epic short, it can handle plenty of rough trail but if the majority of your riding is big drops and jumps I would go Stumpy.
    Jun 2010
    I went with the stumpy and its a blast. My friend has the epic and its a wash, actually maybe a tad slower in the really rough stuff.
    DTL
    DTL is offline
    Jan 2009
    I was facing the same debate about a week ago. I decided to go with the epic 29er comp. Most of the trails I ride are xc single track, rooty with short steep and long gradual climbs depending on which trial I'm on. I'm not into drops and jumps (too old for that) but do appreciate a bike that smooths out my ride. I've only gotten one short ride in on my epic since saturday and the front and rear suspension weren't even dialed in. It still felt wicked fast and does accelerate quickly. You can open up the brain to completely soft if you like or firm it up for climbing etc. Even in the firm position you can barely notice a delay when you role over a bump and it opens up. 4 inches of travel is usually plenty for a 29er unless like previously mentioned you are riding real agressive trails with jumps, drops, rock gardens etc. I liked the stumpy comp too but wasn't comfortable with just relaying on the triad shock for my platform and the stumpy expert (with brain) was too much $. I'm coming off a giant trance x with 5 inches of travel front and back and feel that the epic will do everything I've ever asked of the giant, even more. Like mentioned before it really depends on the kind of riding you do. If you are pointed downhill most of the time stumpy (hence the through axle on the front). If you are more xc guy then epic (throughaxle on rear). The epic 29er IMO has evolved into a bike that stratles the fence between xc and trail bike depending on how you have it set up. Hope this helps.
    Dec 2009
    Yea Thanks for all the input. I think the Epic comp 29er is the one I will go with. Seems to be what will suit me best.
    DTL, what color did you get and hows it look? I will probably go with the silver/black/red one. The lime green I'm not to sure about. I would have to see that in person and the LBS only has the silver/black/red one.
    DTL
    DTL is offline
    Jan 2009
    I went with the silver/black/red. I wasn't too excited with the color at first but it does look a lot better in person and I've grown to like it a lot now. It has a flat finish to it so it's not all shiny. I don't think you will be disapointed with the bike. It accelerates scary fast and like I said my first ride was total fun and I didn't even have the suspensions dialed in. Just went from the shop to the trail. To me this bike is plenty rugged enough for xc/trail riding. The frame apears to be made just as burly as my giant trance x and that is classified as a trail bike.
    I'm also in the same spot. For the past few seasons i've mainly been riding smooth xc trails but would like to get more into some rougher riding. which is why i'm considering the SJ.
    However i'm concerned that for the times I do ride xc trails (esp. the uphill parts) the SJ will be too much bike.
    or should I just go with the epic which I know is going to be a fast bike?
    Split the difference and go with a camber?
    Canuck in the homeland
    DTL
    DTL is offline
    Jan 2009
    It's a tough choice between the stumpy fsr 29 and epic 29. I liked the stumpy too but when test riding noticed it did not accelerate and get up to speed as fast as the epic. Plus the stumpy having 130 mm travel front and back was kinda overkill for the type of riding I do most of the time. It really comes down to the type of trails you spend the most time on. Or, like the last post suggested you could always go camber 29er but that actually has the same travel 100mm as the epic if I'm not mistaken.
    Ill second the Camber suggestion, the pro 29er should hit the spot
    I think for what I ride 80% of the time the epic would be the perfect bike. But there are some days I just want a trail bike. I'm pretty sure I'll get the epic over the camber as I really like the brain on the epic.
    earlier in this thread someone was saying you could set up an epic to be more suited to trail riding, how would someone go about doing this?
    Jan 2009
    Epic worked as a trail bike for me here in Tahoe for couple years, nice bike (26).
    Add some beefy tires: ie: 2.2 Spec. Purgatorys control model (2.4 in the front if you ride the rocky areas).
    Convert to tubeless, use stans juice and run a lower air pressure.
    Wide low rise carbon bar
    Softer seat, like WTB rocket V
    The list can go on, but just set up the shocks for a more all around trail ride, less towards the firm race side.
    Have fun
    Dec 2009
    I picked up my Epic Comp 29er yesterday. I'm hoping to get out today for the virgin ride. I am really happy with my decision so far. This bike just looks fast and pretty solid. The actual trail ride is all that's left to do and I don't think I'll be disappointed.
    I was just looking at the specialized website and they have an epic evo 26er that is build up for exactly what i'm looking for, except that its 26"
    all that they changed on the bike was the tires, handle bar, front disc rotor and a longer travel suspension fork.
    maybe i'll just copy that bike with the exception of the fork
    Dec 2010
    DECKMAN, any further feedabck...?
    The Epic is a very capable trail bike its a 29er and like another one said if u choose ur tires correctly u won't have any problems at all. I have ridden my epic in all kinds of gnarly stuff and i run a rigid on the front, but thats just me. I hated the reba on the front and my Niner carbon fork will be here tommarow. The speed of the epic is what does it for me not just in the down hills as an overall fast bike in all conditions. The thing to remember is its a 29er and the things that gave ur 26er some trouble won't to ur 29er. I use to ride a Intense Spider 29er with a modified Talas 36 on the front and a Pushed high volume can on the rear setup for drops and such. Yeah the spider was cushy but on the epic it just begs to go fast and will take whatever u throw at it. Throw a Ardent 2.4 on the front and ur golden with a fast rear tire. I have been on my epic 2010 for a year and half, rode in Tahoe on 6hr epic and hella rocky terrain and it was a blast.
    "It Is What It Is" Phil 4:13
    B-Ray Da Beast
    Dec 2010
    Sounds like the right equipment for me. Would prefer Shimano over the standard X7/X9 stuff though, but thats just me.
    JRR
    JRR is offline
    I want a 29 epic with a 120/95mm talus 15mm fox fork.Just seems like that would be the best of both worlds.
    ... and if we just ... Yep Yep
    Quote Originally Posted by JRR
    Yea thats the way I would go if I end up getting a suspension fork Talus 95/120 terrlogic fork would give all u the best of both worlds.
    B-Ray Da Beast
    Any specific/different advice for 6-3, 235 lb rider, rocks all shapes/sizes, 35+ mph? Currently on 2010 Fuji 9er HT 80mm Reba. Wanting smoother ride over rocks/ruts. Leaning Epic, presumably smoother than my Fuji HT. OTOH, my first mtb was nice, an SJ FSR 26 (never ever going back to 26).
    jimbo
    www.jamesromeyn.com High End Audio
    www.prime-vibe.com guitar & violin seasoning device
    DTL
    DTL is offline
    Jan 2009
    BRAY explained it perfectly above IMO. The 2011 Epic 29er is a very capable trailbike. 4 inches of travel is plenty on a 29er for most riding conditions other then big jumps/drops. The 2011 Epic 29er frame is pretty stout and beefy. This can be appreciated when seeing one in person and the rear end is plenty stiff so there will be very little lateral flex if any. The best thing about is is you can tune it to be a fast xc race bike also. Like BRAY mentioned, it's fast. It almost feels as if it goes on its own. It accelerated faster then the stumpy fsr 29er I rode and that's what sealed my decision. The stumpy fsr 29er is an awesome bike as well it's just suited for a different type of riding in my opinion. More all mountain stuff.
    DTL
    DTL is offline
    Jan 2009
    Quote Originally Posted by speare
    Open up the brain all the way to full squich and run a lower psi in the positive air chamber of the reba fork. You could also run a lower psi in the tires for more cush. The epic can be run as a very capable trailbike. Keep in mind my opinions are basd off the 2011 epic 29er. I can't comment on a Epic 26er since I'ver never ridden one.
    I spent over an hour looking at the '11 Specialized and '11 Trek/Fisher offerings, doing my best to focus only on 9ers and to ignore the other numerous bikes. I presume many others are like me, dazed at the marketing departments constantly splitting the market into finer and finer segments. This happened earlier in the motorcycle market...where once were 2-4 categories are now about a dozen. The razor thin splitting of market segments signals both the MTB world's financial success and simultaneously its self-destructive tendency at the hand of the marketing departments. One could make an argument that a novice or someone returning to the market could react to the selections with dismay and confusion. I overheard a conversation at Al's Bike Shop in Logan yesterday between a shopper and a salesperson...I almost feel sorry for salespeople stuck trying to make sense to shoppers of all the selection. Please return to the original topic, sorry. Even in my case, I know I'd prefer a FS, but not looking forward to the tuning options of the rear shock.
    jimbo
    Cars Hurt.
    A friend of mine cracked their Epic frame around a month ago. They do regular 3'-4' drops. Specialized warrantied it no problem but when talking to them Specialized said the Epic wasn't really meant for that kind of treatment and he would be better with the SJ.
    Granted rider weight and smoothness also is a factor. Some guys could do drops like that for years and never hurt the frame. My friend is 180lbs.
    Trying not to kill myself
    Reputation: gabe23's Avatar
    Aug 2010
    I don't disagree, but ultimately when you cut through the marketing spin these are all good bikes that will handle the vast majority of terrain that riders will encounter. Like mentioned above, you can set up the Epic to be a very capable trail bike, and someone with the proper engine could race a Stumpy and be quite successful. In the case of the two bikes the OP mentioned, the big difference in my mind is the Brain shock. It's not for everyone, and there is a different level of maintenance involved. Before I bought my HiFi, I demoed an Epic for a couple of days. Awesome bike, but I found that the Brain was overkill on the relatively flat/rooty trails in my area, so I went with a conventional rear suspension setup.
    Quote Originally Posted by ro7939
    gabe23,
    The caption under your username "kills" me! There seems to be some type of unbreakable link between fun, thrills, and danger for a certain group attracted to fast turning wheels.
    I owned an Epic Carbon FS 26 (w/ Brain) for a short time. Gabe's post above describes my experience and conclusions far better than I ever could. This is extremely helpful in my decision making process.
    LetsTryScience's post also very helpful.
    Sunrise in Logan rents MTB for $50/day. I'll rent the new $2400 Giant alum FS 29 when it arrives April...my first trail ride on FS 29. 29s just go so fast, but over the rocks here, even up on the pedals, is not fun with the bike jumping in the air so much. It's a strange vicious circle, the 9ers go faster, which is great, but the faster you go over rocks the more desirable seems FS.
    Pavement spin in the rain today...still waiting for north Utah thaw...maybe late June? Still better than Vermont, where I hear, if you miss 4 July you missed summer!
    jimbo
    Mar 2011
    Hi everyone I am am this same boat and I wonder why the camber is not being discussed, I thought this is exactly why this bike was created. I have always been a XC rider never leaving the ground but over the past year I find myself exploring more and wanting to go up/over rocks, off drops up to 3-maybe 4 ft and generally more "playful" and challenged. I expect to be out riding for fun XC somewhat rocky/roots technical trails 70% of time, 10% xc race (6 to 20 miles) and 20% features, drops and DH. I have been thinking the stumpy was too much bike for my avg/normal rides (like driving a SUV to go grocery shopping in the summer) and the epic was too aggressive geo and racy for my trail/drops/fun riding.
    Therefore I was looking at the camber pro 29er but I am missing something because you guys are not thinking camber?? It is basically the same price as the stumpy 26er elite with brain (or for less is stumpy comp no brain) and the epic comp 29er
    Sorry for straying OT. I don't think you're missing anything. The Camber seems to slot between Epic and SJ. Another potential advantage for the alloy Camber is dual crank. Only potential downside is its "Brain" suspension; my personal style/needs appear better suited for regular suspension.
    I'm dreaming carbon, but financial reality requiring the $2700 SJ alloy "FSR Comp" 9er dual crank.
    jimbo
