Results 1 to 3 of 3
    dog lover-not in that way
    Reputation: 417markg's Avatar
    Nov 2007
    08 Stumpy FSR w/ 203 rear brake rotor problem
    I don't know if this has been mentioned before, but if you put a magura louise 203mm rotor on the rear wheel of a 08 stumpy with the AFR shock the rotor will rub the back edge of the AFR brain.
    I guess I'll be going with a 180mm rotor but now I have to get an adapter..... 203 was overkill anyway
    If the brain didn't lean back there would be room.
    203 rotor problem
    Um why would you want to put a 203 rotor on the rear? the 203 is a front specific rotor, you can lock the 174 rotor up with one finger, and thats just more unnessicary weight.
    Nov 2007
    I don't know why.....why not?
    I have a 203 front/rear kit so I tried to install it. I know it's unnecessary, but the so are a lot of the upgrades we put on our bikes. I have a 180 rotor from another kit and I've ordered the adapter so that's what Iíll use. I was just trying to give others a heads up so they wouldn't buy something they couldn't use.
