Results 1 to 2 of 2
    jason8265
    Guest
    08 Epic Frame - 120mm Fork
    One of the frames being offered under warranty to me is an 08 Epic Marathon. I would likely look to run the 120mm Marz I had on the bike before and wanted to know if others are running slightly longer forks on this version of the Epic and with what results.
    You can def. run the 120mm fork on the Epic, it will change the handling slightly but not that much. Just adjust your cockpit accordingly.
