Results 1 to 2 of 2
    Reputation: Purs's Avatar
    '07 Stumpy fork question
    I've got an '07 SJ FSR Expert with this fork:
    Fox Talas RL, 100-140mm, rebound/compression adj, lock out, alloy steerer
    It's got 3 settings on the top left fork, 100, 120, and 140. I can't tell much, if any difference when I move the switch. Is there a way I can tell if I'm getting the full 140mm of travel? Should I have had to remove some spacer that I read about to get the full 140?
    thanks!
    2010 SC Blur XCc
    hummm! should I?
    Dec 2005
    The travel adjust will only decrease the travel on the fork after you cycle it a cycle of times.
    when you use the three way switch to go back to 140 it should come back to full travel pretty quick.
    You should not have to remove any spacers.
    If you cycle the shock and no change in travel occurs then it appears that you have a broken talas adjustment. You will need to take the fork into your dealer and contact Fox for service/warranty
