'07 Stumpjumper FSR Carbon Pro headset ??
Hi All
Recently I purchased a Chris King Inset headset thinking that is what I needed to replace the existing headset in my '07 SJ FSR Carbon Pro.
Serviced the forks no problems then removed the headset only to find it is very different than I thought. Fitted was a Cane Creek labeled VP-A10ACS unit, spent a little time searching Google but couldn't find an info on this part number. It's an integrated item with 25 x 0.125" balls in a plastic race with steel cup inserts which have a stepped profile that fit into the alloy steering head sleeve.
My question - Am I stuck with limited options on headset replacement? Does any one know if Chris King makes an off the shelf item that will fit?
Any help or advice will be greatly appreciated. Thanks in advance.
- You may not post replies
- You may not edit your posts
Forum Rules
