    Scant abuse
    Reputation: Richard's Avatar
    07 enduro questions
    Does anyone know if a pike will fit on an 07 enduro? What's the AC height on the e150?
    Can the spec shock be replaced with a fox?
    thanks!
    r
    Reputation: darkslide18's Avatar
    I dont have the exact measurments but the A2C is going to be less and the pike is 140mm travel VS the 150 for the E150. And yes, you can replace the AFR with a 7.875x2.25 fox shock. You would be better off going with a RS Lyrik or Fox 36, wether it be a Float,Van, or Talas. I sport a 36 talas on mine and it is tits.
    Steering Box Scraper #1
    Reputation: DubStyle's Avatar
    Jan 2009
    I had a Pike from my Pitch on the Enduro. It's .5" shorter in travel, but didn't effect ridability. I now have the e150 going on later this evening.
    Anthony
    ____________________
    www.steeringboxscrapers.net
    Reputation: Whitedog's Avatar
    I have a 36mm Talas 150mm and I noticed it's axle to crown was very close to my E150 fork with the E150 tubes set to the minimum setting (which is the shortest axle to crown).
    According to the link below, the Pike 140 is 518mm while the Talas 36 150 is 545.3mm
    Forks: Complete Axle to Crown Lengths Library
