Results 1 to 3 of 3
    Dec 2005
    06 fox brain fade vs 07 spec AFR?
    Is there a significant difference in performance between the two? I have an 07 stumpy pro with the AFR and love it. I have an in on a carbon 06 that I may get. I have always wanted to ride carbon, but I dont want to go backwards in shock performance. Would it even be worth it or possible to swap shocks to gain the performance back?
    JMC
    Quote Originally Posted by JMCCRNA
    JMC
    I also have an 07 stumpy in expert build , the bike came with the fox brain set up ,
    I had to play around alot with the valving and blow off to get the fox to work well for me.
    I also got the AFR for the bike , and I prefer it over the stock fox ----------------,once I got the fox valved and working well , I can use either and have no problems .
    It will all be up to what you want .
    Dec 2005
    Thanks for the input, I will keep the other frame around till I ride the fox shock. Its good to know they are interchangeable.
    JMC
