Results 1 to 17 of 17
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    04 Stumpy rear triangle
    Should I be concerned about this?
    The GF's bike has been squeaking so I took the rear apart to grease up the pivots. When I disconnected the linkage I had to pull fairly hard to seperate them, and when it did felt like they had been bound up. I didn't think much of it until I went to put it back together, which is when I noticed how out of wack things are.
    Is this normal? Warranty repair? She has taken a few spills, but nothing to ever bend the rear end this far out of wack.
    You can see the rear has been bent to teh right almost 1/4 inch.
    Boomslang
    Reputation: JakeWake's Avatar
    Mar 2005
    Quote Originally Posted by dan51
    Hi,
    JakeWake here - Engineer at Specialized. Some misalignment as you indicate is perfectly normal and won't affect anything. However 1/4" is a little on on the high side, but I still wouldn't worry about it.
    One thing you can do is loosen all the pivots 1 full turn. Then re-connet the seatstay to the shock link. This allows everything to find its most neutral position. Then re-tighten every thing. This will give you the best alignment.
    If it still bothers you, take it too your LBS and we'll take care of you. But since it doesn't affect anything, I'd spend my time riding it.
    JW
    Humpmaster general
    Reputation: Jack Hass's Avatar
    Quote Originally Posted by JakeWake
    Hi,
    Engineer...........so you wear bib overhalls and drive trains?
    Jake,
    sorry to hijack the thread, but is there going to be a 100mm Stumpjumper for 2006?
    your moma's so ugly, one time she looked out of the window and got arrested for mooning
    Team Blindspot
    Reputation: S-Works's Avatar
    Hey Jake Wake!
    Hi,
    JW
    What torque setting for all pivots? I just got an 04 Stumpy 100 as warranty replacement. It took about 80inch-pounds to break them.
    Astigmatic Visionary
    Boomslang
    Mar 2005
    Quote Originally Posted by Jack Hass
    Jake,
    The SJ 100 as you know it will not exist in the 2006 line.
    However, you will find that either the Epic or SJ 120 will fit your needs.
    The '06 Epic now has an adjustable Brain which can give you the ride quality of a SJ.
    The '06 SJ 120 is a lighter frame than the 100 and now comes with Brain technology at the top levels. So it climbs and descends better. What more could you ask for?
    JW
    Boomslang
    Mar 2005
    Quote Originally Posted by S-Works
    The torque specs are available on our web-site.
    The loc-tite usually makes removing them feel like a lot of torque, but you also fighting against the loc-tite bond, so they generally feel pretty tight coming out.
    JW
    Reputation: Murchman's Avatar
    Thanks Jake for posting here it's nice to see someone from Specialized on the forums. My 04 S-works Enduro has the same mis-allignment of the rear triangle and it's good to read that it's no big deal.
    Again thanks for posting.
    I ride with tools
    Reputation: Jim Beam's Avatar
    Post a URL
    JW
    Could you post a URL to locate where these specs are, or provide some other guidance? I have searched all over the Specialized site looking for torque specs for my "04 Stumpy and could not find them?
    Thanks, I hope.
    aka dan51
    Mar 2005
    Thanks for the feedback JakeWake.
    My only problem with it being this misaligned is getting the bolts back in.
    I had to struggle with a few bolts and thought for a while I would never get it back together.
    On a side note, can the ITCH shock be ordered from you guys for the Enduro? My buddy may be buying a new 2005 Comp 130, but they don't come with the ITCH anymore. I absolutley love mine and couldn't see riding the bike without one. Would the older shock even fit the new model. They look identical to me.
    Quote Originally Posted by Jim Beam
    Thanks, I hope.
    Use HELP under their site and enter a search
    http://specialized.custhelp.com/cgi-...ted=1072748211
    Boomslang
    Mar 2005
    It is easiest to reassemble if you put the dropout pivot together last.
    ITCH - that is a good one. You'll have to contact Specialized Customer Service or Fox. I think it will be tough to get though.
    JW
    aka dan51
    Mar 2005
    JW
    Dropout? That's the pivot right behind the bottom bracket?
    No the drop out is where you rear wheel is attached to the frame so it would be the pivot just infront of the rear axel.
    Team Blindspot
    JW
    Didn't find any info on torque specs. on the site.
    here's the text of what the site had in the support section:
    Torque specs for FSR's
    Question
    What are the torque specs for the pivots on the FSR's?
    Answer
    None available
    So, do have this info, or direct me to another source?
    TIA
    Download the Tech manual from the site, it has all the Torque specs in it.
    aka dan51
    Mar 2005
    Question
    Answer
    None available
    TIA
    Right here dude:
    On page 11 there is a chart that references items in a diagram on page 10. For example, item 2C should be torqued to 70-90 in-lbs. Torque specs are in the far right column.
    aka dan51
    Mar 2005
    Quote Originally Posted by Murchman
    Thanks for the clarification.
    Those bolts will probably be the most difficult to get in. I had a real hard time with the right one when it wasn't attached anywhere else. In fact, the right side (by derailer) looked fairly our of alignment, which caused the bolt to be a huge pain to thread.
    Team Blindspot
    Right here dude:
    Thanks, that's what I was looking for.
  1. Matching front and rear travel
    By Call_me_Clyde in forum Shocks and Suspension
    Last Post: 02-24-2005, 11:00 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Elsworth Dare... hit or miss?
    By Korrupt in forum Downhill - Freeride
    Last Post: 08-13-2004, 08:17 AM
  4. 04 Stinky, 04 BigHit? or 04 Atomik?
    By Phil_Mosco in forum Downhill - Freeride
    Last Post: 05-13-2004, 12:29 AM
  5. Research help
    By mg5904 in forum Bike and Frame discussion
    Last Post: 04-13-2004, 06:32 PM
