    Reputation: Archangel's Avatar
    New question here. '04 S-works Enduro pivot play ?
    Hi guys, please help me with this one!
    I bought a new unbuilt 2004 S-Works Enduro from eBay a while ago. Just received it on Friday. When holding the frame I noticed a clicking sound. After investigating it, it seems that the sound comes from flipflop link pivots as there would be play in pivots/bearings already. When I pull from seatstays backwards, it seems like the link moves a bit and that's when it makes that sound.
    This seems really weird because it is a brand new frame. I think I should try to tighten the pivot bolts and if that doesn't help or they can't be tightened, what should I do ? Keep my 2002 Enduro and sell the S-works frame or change the bearings on the S-works frame or what ? Have you guys encountered similar problems ? I've heard that the upper shock bearing goes out very fast on 2004 models but I've never heard of play in pivots of a new frame.
    Body Shot Specialist
    Reputation: tequila joe's Avatar
    ... and if we just ...
    Quote Originally Posted by Archangel
    I had play and clicking coming from my flip flop link after a very wet and muddy 04 season. My LBS replaced the bushings for $15 and all is good again. Maybe the frame isn't brand new as represents? **shrug**
    If your S-Works frame is a large, I say keep your 02 and sell me the S-Works frame for really cheep!
    T.J.
    LIVESTRONG
    Promlem fixed :-)
    Quote Originally Posted by tequila joe
    T.J.
    I found out that one pivot bolt and upper shock mount (main frame side) bolt were really loose. After I tightened them, the clicking sound and play went away. Simple solution for a simple guy
    It's a medium by the way...
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    keep an eye on that lower pivot bushing.
    www.betd.co.uk has as an upgraded "strong" shock bushing that I recommend. I'm nore sure if specialized switched to a 1 piece bushing by 2004. all the new FSR bikes seem to have them though.
  1. PUSH upper pivot on 5.5...
    By spaeth in forum Intense
    Last Post: 04-22-2005, 02:27 PM
  2. Replies: 63
    Last Post: 04-14-2005, 05:07 AM
  3. Single pivot haters
    By GGAllen in forum General Discussion
    Last Post: 11-07-2004, 11:15 AM
  4. Elsworth Dare... hit or miss?
    By Korrupt in forum Downhill - Freeride
    Last Post: 08-13-2004, 08:17 AM
  5. 04 Stinky, 04 BigHit? or 04 Atomik?
    By Phil_Mosco in forum Downhill - Freeride
    Last Post: 05-13-2004, 12:29 AM
