Results 1 to 3 of 3
    03 S-works enduro owners, few ???
    I just posted this question in the drive train section but I'm also posting here just in case I can get a quick/more help here, I don't usually check other part of the forums I visit.
    Copy/paste
    I have an 03 specialized s-works enduro that I just acquired and it came with a 113mm bottom bracket and from the factory this bike came with a 133.5mm.
    I'm new to this and I would like to know what can I used to replace this to be close to the original specs.
    I just a new to me frame so I need to start buying components and this is why I'm asking for help, because I don't know what should I buy now and don't know if I used this current BB I could have alignment problems with the chainrings and the cassette.
    Here's a copy paste from specialized.
    CRANKSET Shimano M-960 XTR Hollowtech II arms
    CHAINRINGS44Ax32Ax22A, 7075 Aluminum, 44 Anodized, 32/22 Nickel-Plated, 4-bolt, 146/102/64mm pattern
    BOTTOM BRACKET Shimano M-960 XTR, Octalink spline, combined w/ crank, 68mm shell width, 133.5mm spindle length
    In this case what should be my best option to go with?
    Thanks in advance for any help.
    adamant
    basically you can use any 3x or 2x crankset. Shimano outboard bottom bracket style crankset will work on that frame. As will any Sram/Truvativ "GXP" outboard style crankset. Many options.
    ok, so in this case what size do I need? or how this work in this case, do I need to measure in mm, like 133.5 or how?
  1. S-works owners,,,,,,post your pics
    By orangespot in forum Specialized
    Last Post: 10-09-2015, 03:23 AM
  2. 2012 enduro owners
    By stokerslo in forum Specialized
    Last Post: 01-07-2013, 11:33 AM
  3. Calling out Enduro EVO owners!
    By RoninX in forum Specialized
    Last Post: 01-20-2012, 02:39 PM
  4. '11 Enduro Evo owners, how does it pedal?
    By crashedupderby in forum Specialized
    Last Post: 04-10-2011, 09:41 AM
  5. '11 Enduro Evo owners, how does it pedal?
    Last Post: 01-14-2011, 02:40 PM
