Results 1 to 2 of 2
    '02 Specialed Enduro Expert
    I am having problems with my rear shock and fork. The rear shock will not hold air and I am looking for a replacement anyways instead of rebuilding it and the forks u-turn is busted and springs are to soft. I am looking for some replacement ideas i am doing a lot of 4ft drops lately and just want to have a better ride.
    Reputation: Stumpy_Steve's Avatar
    you might still want to stick with coil up front, like either a pike or fox van with your drops. pike has the 20mm hub so youd need a new front wheel, but upgradings fun, right? for the rear, im sure theres an rp23 or somethin other built in that size. otherwise, get your shock pushed, get one from reese racing (or whatever), or upgrade. that frame is old, and spesh is blowing out the 06/07 non sl enduros...
