Results 1 to 5 of 5
    ** help needed where to buy "top hat style"washers? ** (spec dualie)
    hey,
    im doing a little overhaul of my specilized bighit and have managed to loose one of the "top hat style washers(photos below)"
    has anyone had any luck with getting their hand on some new ones?
    if so where did you buy them from? or where should i go looking for them?
    cheers Tim
    fnar fnar brrraaaaap
    Reputation: ilostmypassword's Avatar
    Quote Originally Posted by exvitermini
    hey,
    cheers Tim
    maybe call specialized or your LBS??
    Big Paws on a Puppy!!
    Reputation: Ratman's Avatar
    May 2005
    May be a shot in the dark....
    ... but if specialized or your LBS can't help you might try here: http://www.grainger.com/Grainger/wwg...s&stype=CATIDX
    I've had some really good luck with these guys finding small parts for everything including my bikes, my boat, and stuff around the house.
    Good Luck!
    ‎"My bicycle masters boardwalk and quagmire with aplomb." - Tom Nuttall
    Crunchatize me Capn'
    Reputation: jabpn's Avatar
    You are probably going to have to get them from Specialized via your local Spec. dealer. Most parts like this are completely proprietary to the company. Not only just in design (ie top hat design) but sizing as well.
    Reputation: FireDog46's Avatar
    Shoulder Washer
    hey,
    cheers Tim
    A "top hat washer" is something completely different.
    What you're looking for is actually called a "shoulder washer".
    A "shoulder washer" acts as an isolator/retainer/reducer and
    are used in all kinds of applications. For us they are used as a retainer/reducer.
    I too have been trying to source metric "shoulder washers" with little luck.
    If I want hundreds of the damn things, there's all kinds of companies to choose from.
    Special order from Specialized through your LBS is probably the only way.
    Or a friend with a machine shop. Or a small length of metric tubing as a reducer
    and an over-sized washer as a retainer.
    michael
    "Be not afraid of going slowly but only of standing still." - Chinese Proverb
