Results 1 to 3 of 3
    Feb 2006
    Best Tires/ Lube for MS riding?
    Can anybody give a suggestion for the best tires and/ or lube to use around MS? I primarily ride at Little Colorado if that helps. Thanks!
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    Quote Originally Posted by TPage1013
    I'm always riding at LC. You don't need big nobbies for LC. I swear by Schwalbe Racing Ralphs, which are similar to Conti Explorers in the tread style/pattern. I know many people like Ritchey Zed tires as well.
    As for chain-lube, I think Pedros Extra Dry is the best thing out there.
    Check out www.msmtb.org for more talk about Mississippi Mountain Biking.
    op (Brian)
    www.msmtb.org - Mississippi Mountain Biking
    Want to vent?
    Reputation: The SS Boz's Avatar
    Michelin XCR Dry or XCR AT is what ive been using around here....its been mostly dry and dusty so huge knobs are kinda overkill right now and for the rest of the summer im guessin...
    I use white lightning for wet conditions or tri flow lube for everything else...
    -Boz
    "I'm supa-fly TNT, I'm tha guns of the navarone!"
