    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    RSS feed and how to set up.
    I have always used an RSS feed to watch the forums without needing to go through my browser. Good for work or anywhere you don't particularly want to be going to the internet.
    A lot of email products and desktop apps support RSS feeds.
    Here is the FAQ regarding RSS from MTBR: http://forums.mtbr.com/faq.php?s=&do...l&titlesonly=0
    Essentially you can get the new posts rss feed by entering into your RSS browser: http://forums.mtbr.com/external.php?type=rss2
    You can get specific forums by using that previous like with the following appended: http://forums.mtbr.com/external.php?type=rss2&forumids=123
    the 123 in the above example is the forum number which is part of the link to your forum of choice.To get the number you will need to right click on the forum page and select "view page source" Then you will need to find the following code:
    1. script type="***************" src="http://forums.mtbr.com/clientscript/vbulletin_global.js?v=387"></script>
    2. script type="***************" src="http://forums.mtbr.com/clientscript/vbulletin_menu.js?v=387"></script>
    3. link rel="alternate" type="application/rss+xml" title="Mtbr Forums RSS Feed" href="http://forums.mtbr.com/external.php?type=RSS2" />
    4. link rel="alternate" type="application/rss+xml" title="Mtbr Forums - Passion - RSS Feed" href="http://forums.mtbr.com/external.php?type=RSS2&amp;forumids=44" /
    In this case around line 326.
    44 is your forum Id number.
    Hope that helps if anyone is interested.
    Try this: HTFU
    The Next 100 Miler
    Reputation: MarkP's Avatar
    I used this to add a feed of the Arizona forum on our website and it showed initially, but the feed is not updating to reflect new forum posts when our page is refreshed. Bottom right side of this page: Desert Foothills Mountain Bike Association
    The Next 100 Miler
    Never mind, fixed itself.
    Quote Originally Posted by MarkP View Post
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    That is some great info there...can you get a specific thread?
  • You may edit your posts
