Results 1 to 6 of 6
Thread: Reply System
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    Reply System
    Someone please try to explain to me how the reply system works because it is very aggravating to make a comment in a large thread expecting it to be the last posted comment only to have it under an existing conversation tangent within the thread? which sometimes is nowhere near where i wanted my comment to be displayed. There are 5 options. 3 of which that are incorporated into a stand alone post " Quote, Muti-Quote This Message, Quick reply to this message", which are self explanatory.
    Underneath the last posted message there are two options. " Post Reply, and Post Quick Reply/ Go Advanced". .. this is the only known unstructured replay system i've ever dealt with.
    so why is it that " Post Quick Reply" follows the last known posted comment and isn't the last post of the thread?...
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Are you using Linear mode?
    Feb 2006
    what's that boss? and how do i change it
    '11 Jedi
    Feb 2006
    never mind, i found it... as long as i've been on there i should have known better
    '11 Jedi
    AZ
    AZ is offline
    Upper right hand corner where is say's "display modes". Click it and it drops down, select :linear mode".
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Don't forget to use the 'quote' button unless you are sure that you are fast enough to reply with ^^^
    And yeah - linear mode - I can not fathom why there are the other options and even then, linear is not the default -
    FC, gregg, how about disabling those other modes?
    Honestly... ahh I give up
  • You may edit your posts
