Server Error in '/' Application.
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Source Error:
Line 288: module.CurrUrl = m_Url;
Line 289:
Line 290: this.Controls.Add(module);
Line 291:
Line 292: if (m_bShowLoadTime)
Source File: d:\ConsumerReview\App_Code\Controls.cs Line: 290
Stack Trace:
[SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)]
System.Data.ProviderBase.DbConnectionPool.GetConne ction(DbConnection owningObject) +428
System.Data.ProviderBase.DbConnectionFactory.GetCo nnection(DbConnection owningConnection) +65
System.Data.ProviderBase.DbConnectionClosed.OpenCo nnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +117
System.Data.SqlClient.SqlConnection.Open() +122
System.Data.Common.DbDataAdapter.QuietOpen(IDbConn ection connection, ConnectionState& originalState) +31
System.Data.Common.DbDataAdapter.FillInternal(Data Set dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +112
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +287
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet) +94
ConsumerReview.HotdealsTwo.Page_Load(Object sender, EventArgs e) +780
System.Web.Util.CalliHelper.EventArgFunctionCaller (IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Cal lback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.AddedControl(Control control, Int32 index) +265
System.Web.UI.ControlCollection.Add(Control child) +80
ConsumerReview.CachedChannelModuleControl.CreateCh ildControls() in d:\ConsumerReview\App_Code\Controls.cs:290
System.Web.UI.Control.EnsureChildControls() +87
System.Web.UI.Control.PreRenderRecursiveInternal() +44
System.Web.UI.Control.PreRenderRecursiveInternal() +171
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +842
Version Information: Microsoft .NET Framework Version:2.0.50727.3643; ASP.NET Version:2.0.50727.3634
Results 1 to 3 of 3
Hot DealsContestsLatest Mountain Bike ArticlesVideosMTBR on Facebook |
LinkBack URL
About LinkBacks
