Results 1 to 3 of 3
    Registered text offender
    Dec 2011
    Classifieds feedback after ad removal?
    I recently made a purchase off a fellow member that was very positive. I would like to leave positive feedback, however the ad has been removed.
    Can someone clue me in as to how to go about leaving feedback that will appear in the classified section post ad removal? The sellers screen name is lone pine.
    Reputation: marpilli's Avatar
    Here's a response to the same question (but the original ad was still available):
    Quote Originally Posted by marpilli View Post
    1) Go find the advertisement in question and pull it up on your screen.
    2) Under "Seller Details", click on the seller's name (it's a hyperlink).
    3) On the left hand side, you should now see a column of options. About the 5th option down is Feedback. Click it...
    4) Select the appropriate rating, enter any comments you want, and click Submit.
    I might be able to figure out a link to the member's classifieds profile. Do you remember the MTBR user name?
    EDIT: Yes, I can build a link to the user's classifieds profile.
    Look up the user name in the Community User List.
    Once you find it, note the "u=xxxxx" portion of the url. Where xxxxx is a set of numbers.
    Add that set of numbers onto this url:
    Code:
    http://classifieds.mtbr.com/member.php?uid=
    That should take you to the user's classified profile.
    If it's confusing, post up the member's name and I'll build the link for you.
    Dec 2011
    That worked! Thanks marp
    I had made it as far as finding him on the user list before I posted but was at a loss as to where the feedback clicky was hiding.
    lone pine is the users name, if he has something you want you can buy with confidence he'll give you a fair shake and do so expediently.
    That was really very helpful of you, much appreciated.
  • You may edit your posts
