Results 1 to 3 of 3
    xt hub solid axle size ?
    i just bought an new surly 1x1.My lbs converted the rear xt hub to a 10mm x 174 mm axle.
    im using a tugnut on one side and track type nuts(with attached serrated washers).
    the nuts are only catching 3/4 of the threads.some pepole seem to think its fine.
    i would like the nuts completely on the axle.
    ive been told to try a 9.5mm x 187mm length axle.
    has anybody done this?
    thanks
    paintbucket
    Reputation: wooglin's Avatar
    Not much joy, huh? Mean Todd at webcyclery.com hooked me up with a 187mm solid axle that works great on my 1x1. As for the 9.5 vs. 10, I assume that's diameter or something. Change that and your nuts won't work anymore. Chicks don't dig that at all.
    When the going gets weird its bedtime.
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    Quote Originally Posted by bluecruz
    10mm x 174 mm axle.
    If the 10mm x 174 anxle worked but was just oo short - you still need a 10mm axle but longer - so if you could find a 10mm x 187mm axle you'd probably be in business.... and if you have to go with the 9.5 axle you are going to have more than nut problems- the bearing cones that thread on the axle will be the wrong size also...
    Hope that helps
    FF
    "If I'm leading, I'm bleeding."
  1. Replies: 39
    Last Post: 08-14-2004, 06:09 PM
  2. What cassette and where?
    By uofabill in forum General Discussion
    Last Post: 04-06-2004, 10:22 AM
  3. Solid axle for my Vanilla 125R ?
    By keen in forum Shocks and Suspension
    Last Post: 03-31-2004, 08:15 PM
  4. QR to XT solid axle info needed?
    By keen in forum Wheels and Tires
    Last Post: 02-25-2004, 04:20 PM
  5. Drilling out solid axle off-center?
    By jh_on_the_cape in forum Singlespeed
    Last Post: 01-14-2004, 12:26 PM
