Results 1 to 6 of 6
    XT crankset conversion to single speed
    I just got an XT crankset hoping to use the middle ring only, but when I remove the outer ring the nuts and bolts that hold the middle ring on are too long to snug it up. Can I fix this without running the big ring or a bash guard? Any ideas would be greatly appreciated.
    Reputation: scooter916's Avatar
    either use single speed chain ring bolts (LBS >$10)
    or chain ring bolt spacers (few buck less than the bolts)
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    old enough to know better
    Reputation: headhunter's Avatar
    Sugino Steel Bolts
    My LBS had some Sugino steel bolts that are awesome. The steel allows a much higher and better torque to be put on the chainring than aluminum. Not much is more annoying than having your chainring come loose...
    I always use Truvativ dual hex head steel chainring bolts that come with the spacer. Works great and less than $10 for 5 bolts and 5 spacers.
    Cool thanks guys. I'll check out the shop in the morning.
    Let's ride
    Reputation: rensho's Avatar
    Go to any bike shop that sells bmx bikes. They have SS chainring bolts all day long.
