Results 1 to 24 of 24
Thread: Will This Work?
    Reputation: kylebooth's Avatar
    Will This Work?
    I went on PricePoint.com and picked out 3 parts for my single speed project...can you guys help me out by telling me if this is all i need and if it will even work. My bike is a 2009 norco rival.
    Tensioner - http://www.pricepoint.com/detail/141...-Tensioner.htm
    20 tooth cog - http://www.pricepoint.com/detail.htm...0&style_id=065 Q2PPC9
    Cog Spacers - http://www.pricepoint.com/detail.htm...3&style_id=065 RENSC6
    I have never worked on a mountain bike before so this is all new to me...i just need to know if this is all i need to convert and if all these parts will work with my 09 rival thanks alot.
    My Ride - 2009 Norco Rival - Single speed
    I'm just messing with you
    Reputation: wv_bob's Avatar
    If it were me, I'd avoid the alloy cog and go with a Surly
    Other than that you should be good to go.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    so thats all i need and everything will work fine. Why go with a surly?
    The surly is steel so it will wear less.
    I make no guarantees
    Have you got a chain ring already?
    Cant i just use my old chain ring?
    in the description of the tensioner i have picked out it says
    " Improved for 2005 the new DMR Tension Seeker 2 is completely revised and is designed for cross-country applications. The main difference is a new rigid frame mount that fits any frame with a normal dropout and a new spline drive spring system. Features double sealed pivot bearing and alloy pulley with sealed cartridge bearing with a tough anodized finish."
    does that mean it wont be good for trail riding / dirt jumping?
    Please use a fixed tensioner instead of a spring mounted one. A fixed one is better in every way.
    oh. i thought that one was fixed...what would you reccomend from pricepoint.com
    thanks..did you take a look at the spacer kit and the cog...will that all work fine for me on my 09 rival?
    I think 20t will be too low a gear for you. I'd suggest this instead:
    http://www.pricepoint.com/detail/167...ersion-Kit.htm
    It comes with both a 16t and an 18t so you can experiment.
    awesome maybe ill get the 16 18 and 20...its only 11 dollars! but is that spacer kit i picked out fine?
    The kit I gave the link for comes with spacers, so it'll save you $30.
    last question that kit only comes with the 3 spacers is that enough? and should i get the single speed chain for 5 bucks
    http://www.pricepoint.com/detail.htm...3&style_id=070 KMCZ46&detailName=KMC Z410 Single Speed Chain&dept_id=&deptName=&sub_id=&subName=&lprice=5 .98&hprice=5.98
    Quote Originally Posted by kylebooth
    Actually that's two spacers and a lockring. I bought one of those kind of spacers, and coudn't get the chainline right. I'd be happy to give them to you but they probably won't work for you either. I used a rockwerks (IIRC) spacer kit I got off ebay - $10 including shipping IIRC.
    Yes, they're enough 95% of the time.
    No, skip the single speed chain and just shorten your existing one if it isn't worn. If need a new chain, I recommend the SRAM PC-870.
    how would you be able to give them to me? ship them?
    ok thanks alot for the help...i appreciate it. sorry for all the questions...i hope the spacers will be enough this is what i have in my shopping cart
    http://www.pricepoint.com/detail.htm...4&style_id=075 RENRL6
    http://www.pricepoint.com/detail.htm...7&style_id=065 SETSC7
    http://www.pricepoint.com/detail/149...peed-Chain.htm
    what do ya think?
    I would hold off on the 20t cog. If the 18t is too hard, then spend the money.
    Don't buy a 1/8" chain. They're heavy, annoying, and don't work as well as a 3/32" chain. If you need a new chain, then buy this:
    http://www.pricepoint.com/detail/170...rlink-2008.htm
    ok thanks alot! i will do that...the only thing im worried about is the spacers....but iam sure you know what your talking about! i will order the stuff today..do you want to see my bike when its done!?
    If the included spacers don't work, you can always build your own from PVC. There's no reason to spend a lot of money converting a bike to single speed. If you try it and like it, then you can start looking at buying nicer bits.
    ok ...so ill just get the 2 cog and spacer kit for 11 bucks and the tensioner you recommended for 50 bucks and use my old chain! thats the cheapest way to go..
    Word.
    disc breaks dont cause a problem when converting do they?
    No.
