Results 1 to 10 of 10
    Will the DT Swiss RWS Thru Bolt work with horizontal dropouts single speed?
    Hi
    I converted my transam to single speed.
    It has horizontal dropouts and I dont have an axle that fits. The dropout is for 135x10.
    I found this one and I'm not sure if it will work with horizontal dropouts ss.
    Anyone has any experience with it?
    https://www.dtswiss.com/Components/R...S-Thru-bolt-en
    Evil The Following MB 2017
    Canondale Scalpel Team 2015
    Kona Raijin 2014 SS
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Should work with no problem. I ran one on my original Tallboy to help stiffen up the rear end. The dropouts on the rear of most QR frames are 135x10.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Wanna ride bikes?
    Oct 2013
    are you sure your hub will take the 10mm TA? a 10mm QR is not the same thing.
    but to answer the original question, yes, the 10mm TA will fit.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I use the DT front wheel RWS and their 135mm bolt option on the rear (similar to Chris King FunBolts) for a couple of custom steel single speed frames with sliders. Both CK and DT rear bolts still slip toward the drive side on log rides with lots of climbing for me. I am going EBB with standard dropout on my next SS frame (like I had on my Niner SIR 9 w/ standard rear dropout that worked like a champ).
    I use a Hadley H500260-CLR 10mm X 1.25mm X 166mm thru axle on one of my standard dropout 29er hard tail frames that I've bent multiple rear skewers on. That one has CK rear hub with the standard axle end caps removed. I imagine you can do the same with a DT rear hub.
    Will the DT Swiss RWS Thru Bolt work with horizontal dropouts single speed?-image1-1-.jpeg
    【ツ】 eDub 【ツ】
    Jan 2009
    1+ for Hadley thru bolt.
    Reputation: dbhammercycle's Avatar
    Hadley ftw.
    But yes, DT swiss 10mm bolt in track ends will fit. No idea of slippage though, chain tensioners?
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    I got an official word from DT and they told me it is not suitable for Horizontal Dropouts
    Kona Raijin 2014 SS
    WNC Native
    Reputation: nitrousjunky's Avatar
    Quote Originally Posted by we78 View Post
    I ran a DT350 rear hub with the 135x10 DT RWS Skewer on a SS Surly Krampus for about 6 months. I'm a 200lb masher and it never once moved.
    YMMV but it worked nicely for me.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Bah. Worst case scenario, use 10mm chain tensioners...
    SSolo, on your left!
    Quote Originally Posted by *OneSpeed* View Post
    X2
    Quote Originally Posted by dbhammercycle View Post
    X2, but I would just bolt it on and use some chain tugs like the Redlines, is what I use even with my bolt on axles. I'm 190lb aggressive rider and this ensures the axle never moves and makes it so easy to fix flats and still put the wheel back on in same place with same chain tension.
    Chain Tensioners | Components | Redline Bicycles
    Get off the couch and ride!
  1. Building Single Speed with Horizontal Dropout
    By bcolby23 in forum Singlespeed
    Last Post: 05-10-2016, 12:31 AM
  2. Looking for intense hard eddie single speed dropouts
    By isaiahf8 in forum Singlespeed
    Last Post: 01-19-2016, 05:46 AM
  3. Nexus 3 speed & Surly horizontal dropouts???
    By JeepDave in forum 29er Bikes
    Last Post: 11-26-2012, 08:39 PM
  4. 12mm bolt through single speed hub
    By ianpinder in forum Singlespeed
    Last Post: 06-15-2012, 04:26 PM
