Results 1 to 18 of 18
    Suffering Mightily
    Reputation: Drbbt's Avatar
    Who has CK SS disc hubs?
    I'm considering popping for some King SS disc hubs and was wondering what owners of these jewels had to say about them. Are there any cons, aside from the price, that I should be aware of? Has anybody had any trouble with the aluminum freehub body? Thanks in advance--Drbbt
    Reputation: KMan's Avatar
    Mine have been nothing but peeerrrrrrrrfect!
    If you haver the $$ and don't mind the buzzzz, King is the best option in my book!
    SS Chimp
    Reputation: 32x18's Avatar
    got king disc hubs (ISO and Discotek SS) on 2 bikes and i would not change a thing. just do your maintenance and they are great
    No smart comment
    Reputation: nikh's Avatar
    Best in the biz.
    Cyclist
    Reputation: striker's Avatar
    I'll ride no other
    Quote Originally Posted by KMan
    over a year and no problems...
    IF CK made BB's, rims, frames, h-bars, saddles, shifters, chains...I would use them all. CK stuff is solid and good. You pay for it but it lasts.
    "Beer is proof that God loves us and wants us to be happy." -- Benjamin Franklin
    My cycling photos. Enjoy!
    Jackass
    Best $$$$ I ever spent. A little bit of break-in adjustment at first (noted
    in the instructions) the perfect. fuggedaboutit.
    No hairSShirts.
    Jed Peters
    Reputation: Zonic Man's Avatar
    They work great for me. I tend to thrash rear hubs too!
    No issues, but only had the hub for about 10 rides so far.
    cut like the fog.
    Reputation: bones's Avatar
    One season of mud and racing on mine and not a single problem. I actually quite like the sound they make.
    I can't say they're "worth the money" but you won't regret the purchase.
    b.
    Shamisen Appreciator
    I've been running the rear SS Disk on my trials bike for a little over a year and have had no troubles whatsoever. As long as you use a King Kog, you shouldn't have any troubles with the free hub body. (Not that I'm aware of another cog that would fit without modification). I've had many King rear hubs over the past 7 years, and I've found that if you're experiencing trouble with free hub drag, just pop it apart and lube up the bearing seals and ring drive with Tri-Flow.
    Sean
    (aka SS_MB-7)
    Reputation: mike@one-speed.com's Avatar
    Quote Originally Posted by Drbbt
    I've been racing on my King SS disc hub for over a year and it has been flawless! Well worth the 147 days I had to wait for it.
    Prior to my King, I had a Spot disc hub. The Spot uses freewheels, which I hate. I've tried both Shimano and ACS and didn't have great luck with either. They died prematurely, froze-up when cold (typical in Canadian winters), were a nightmare to remove, etc. The Kogs used by King solve the removal issue and the King internals solve the other issues.
    What I find the biggest advantage to be with the King is the instant engagement. You can really notice this benefit when ratcheting up a technical switchback climb.
    So, if you've got the $$ and don't mind the King buzz, get one!
    Ride Hard,
    Mike B.
    http://www.one-speed.com
    HowtoOverthrowtheSystem
    The CK sound
    I like it...the noise is annoying and makes you keep pedaling so that you don't have to hear it hence, they make you faster.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    I don't like it in the cold. I went for a ride last night in 20 degree temps, and the ringdrive thing failed me for the second time, i.e., it stopped engaging with the freehub, so I was freewheeling in both directions.
    I've heard of people changing to a lighter oil/lube in the freewheel, but I've been too lazy. Anyone else have this problem before? Was it easy to do the fix?
    No Fixeyfreeride, I didn't piss on it. I just swapped out with an extra wheel I have in the car just in case this happens.
    (aka SS_MB-7)
    Quote Originally Posted by Drevil
    Hmm, I've ridden mine as cold as -30C (-22F) this winter without any issues. I'm still using the stock internal lube.
    Ride Hard,
    Mike B.
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    ... and if we just ...
    I love my King hubs... I've been on King hubs since 1998 and never looked back. Made the leap to the ISO Disc ones when they came out and other than some maint - they are pretty much a forget it item - other than everytime you coast! ...lol (but the sound is fine with me). No issues with the aluminum cassette body on my SS (I run wide cogs) - although my geary did have a little chewy mark from my XT Cassette (must not have been tight enough) - but it still works fine!
    And I forgot to mention - mine are just the ISO hubs - not the SS specific
    Hope this helps
    FF
    "If I'm leading, I'm bleeding."
    Reputation: General Coonskins's Avatar
    Great product
    I love King stuff, $$ are high but so is the cost of what they do to help protect our enviroment.
    I have King headsets and hubs and can say they almost maintenance free.
    Never had the problem of them freewheeling in cold weather, have had several Shimano hubs do it thow.
    Just the Pictures
    The Shop
    The Blog
    Time To Ride,
    General Coonskins
    Did a search on the old board
    and it doesn't look like I'm the only one:
    http://forums13.consumerreview.com/c...7X2.0@.efda999
    I guess some are luckier than others.
    I've downloaded the PDF manual on King's site and I'll probably break it down soon and put motor oil in there.
    Quote Originally Posted by mike@one-speed.com
    No smart comment
    Mine are for sale amongst other stuff:
    Chris King custom singlespeed wheelset - built by Mtnhighcyclery.
    R: Chris King gold 32h singlespeed disc hub, Sapim CX-Ray spokes (black), Mavic X317 disc rim (black), Sapim nipples (gold).
    F: Chris King gold 32h ISO disc hub, Sapim CX-Ray spokes (black), Mavic X317 disc rim (black), Sapim nipples (gold).
    The wheelset has been used for 200 miles only, immaculate condition 9/10 $ 499
    http://marketplace.consumerreview.co...uery=retrieval
    Reputation: the Inbred's Avatar
    mine will be here shortly.
    there are ~5 King BBs floating around....
  1. Suggestions for 20mm hubs?
    By upNdown in forum Downhill - Freeride
    Last Post: 03-05-2004, 10:54 PM
  2. Debating which XC disc wheelset - opinions?
    By Spookykinkajou in forum General Discussion
    Last Post: 01-23-2004, 03:43 PM
  3. Rear XT disc hub resistance
    By domzanrider in forum Wheels and Tires
    Last Post: 01-20-2004, 04:10 PM
  4. American Classic/WTB disc hubs
    By GrantB in forum Wheels and Tires
    Last Post: 01-19-2004, 08:44 AM
