Results 1 to 7 of 7
    Enthusiast
    Reputation: KK89's Avatar
    May 2013
    What's with the Surly Singleator tensioner?
    I've got really mixed opinions on Surlys chaintensioner.
    Some say it's good.. others it's bad.. So are there monday pieces at the market or can't people read the instruction or shorten the chain enough so it wouldn't jump?
    I never had an issue with mine when I had it. It was setup in the push up configuration.
    Enthusiast
    May 2013
    My cheap no name tensioner is moving sideways and makes noise at every full pedal rotation. I thought I'd make a dinlge-speed tensioner out of this one by adding a pulley wheel from the old tensioner.
    Though for my student budget it's still kind of expensive. That's why I'm asking.
    More opinions?
    More than a little slow
    Reputation: dskunk's Avatar
    It's been years since I had one. Mine worked fine when set to push up. I also had it briefly set up to push down (couldn't shorten the chain more and at the length it was the tensioner hit the chain stay when pushing up) and in that configuration I had trouble with it.
    If I get a tensioner again (which is possible ) I'm going to try something like Paul's Melvin. Nice but pricier.
    Cheers, Dave
    Reputation: zorro's Avatar
    Feb 2007
    Quote Originally Posted by worrptangl View Post
    +1. No issues at all when I used it.
    It's not how old I am, it's how old I feel - Minor Threat
    Moderator Moderator
    Had good results with mine pushing up; the only problem (AND IT COULD HAVE BEEN MY FAULT) was the spring released tension once by the "hook" coming out (internally) when I was far from home; fortunately wired it and had a fixed tensioner until I got home and repaired it.
    Enthusiast
    May 2013
    Some have said when tightened "correctly" chain jumped, and when tightened with your teeth screaking it hold for a second and then snapped the spring.
    I think it must be too long chain.. cause I haven't had an issue (Except what I explained earlier) with a tensioner half the price. Tough I have same number of teeth in both ratios on my D-S.
  1. surly chain tensioner, is it worth the price?
    By winginit in forum Singlespeed
    Last Post: 09-13-2012, 04:06 AM
  2. Surley Singleator
    By trodaq in forum Singlespeed
    Last Post: 03-31-2012, 05:16 AM
  3. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
  4. ETR/B vs. Singleator
    By GVSS in forum Singlespeed
    Last Post: 02-15-2011, 04:45 PM
  5. Surly Singleator question
    By sasquatch rides a SS in forum Singlespeed
    Last Post: 01-12-2011, 07:37 PM
