Results 1 to 3 of 3
    Frequent Crasher
    Reputation: SuperBad's Avatar
    What tool to remove cog lockring on Novatech hubs?
    I need to swap my gearing around, but I have no clue what tool to remove the lockring on my Novatech SS Cassette disc rear hub. Any help would be very appreciated. It looks like there are 6 equally spaced notches like on some bottom brackets.
    Thanks very much.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    I use a Park BBT-7...
    it is the same tool that removes D/A or XTR Bottom Bracket lock rings. The Novatec lockring is steel so any lockring spaner should do the trick.
    The park tool is usually around $15 at your LBS.
    Quote Originally Posted by SuperBad
    Thanks very much.
    Todd............. If you can't be kind, at least have the decency to be vague
    Frequent Crasher
    Thanks very much!
