Results 1 to 2 of 2
    New question here. What BB size for Giant XTC Singlespeed
    I just got a used 2003 Giant XTC frame which I plan to build into a singlespeed. What BB size do I need for this?
    Steamroller
    Reputation: Mattman's Avatar
    Do some measuring and figuring
    Quote Originally Posted by woofers
    Measure the width of the BB shell, probably 68 or 73. Then you will need to decide the correct spindle length. Spindle may depend some on the crank you use, but more on which positon you want to run the chainring in. I like the looks better when the ring is run in the outer postion on the spider but, if you run a bash gaurd or have chainline issues you may run it on the inside of the spider. I've built several SS bikes in the last year and I think all were either 68x110 or 68x113.
    The rear hub can affect the placement of the chainring up front as well, with a cassette type hub you have a much more adjustable chainline than with a screw on freewheel in the rear. Some additional adjustment can be made to the bottom bracket by using spacers there too if you need. It's really not hard, but it kind of has to be figured out. I don't think anyone will be able to give you the answer unless they know the bike and know what kind of hub you are using.
    Two Wheeled and Too Big
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Crank stiffness question...
    By TheSingleGuy in forum Singlespeed
    Last Post: 02-07-2005, 04:54 PM
  3. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  4. What's your preferred BB drop?
    By anden in forum 29er Bikes
    Last Post: 06-17-2004, 06:41 AM
  5. I'z got a BB thang goin on...
    By jrm in forum Passion
    Last Post: 04-22-2004, 08:56 AM
