Results 1 to 13 of 13
    I like rigid MTB.
    Reputation: edle's Avatar
    What is the approv. weight saving in grams if I go single speed ????
    I'm running a 1 x 9 speeds (32T front and 11-32T cassette) now.
    I'm planning to use ENO Eccentric SS hub.
    Thanks.....
    Reputation: AlexCuse's Avatar
    Re: What is the approv. weight saving in grams if I go single speed ????
    This question is impossible to answer without knowing more about your current setup but basically the weight of your current derailleur, shifter and cable/housing (all of which can vary wildly). If you have a heavy hub/cassette currently you might lose a bit more from switch to eno/freewheel but could also end up gaining there. You'll also lose some chain weight.
    Though you'll definitely achieve your goal, switching to SS with weight savings as the primary goal seems likely to end in heartbreak. I'd recommend starting with a cheaper approach (ss cassette conversion kit + chain tensioner or magic gear) to see if you like it first.
    Yeah I only carry cans cause I'm a weight weenie.
    Gotta pay to play
    Reputation: michaelscott's Avatar
    You'll probably save around -2381.36 grams.
    So you'll gain a little over 5 pounds once you switch to SS riding.
    You'll lose a derailer(s) and a cassette but your muscles and genitalia will HULK up.
    Dec 2010
    Quote Originally Posted by AlexCuse View Post
    This question is impossible to answer without knowing more about your current setup...
    This.
    Moderator Moderator
    Reputation: Walt's Avatar
    Not as much as you'll save by ditching the drivetrain entirely and riding a unicycle. Or running naked and barefoot with a single Kooka brake lever clutched in your hand.
    -Walt
    Jan 2011
    Quote Originally Posted by edle View Post
    Thanks.....
    It depends on your current % body fat and how much you ride. But singlespeed is not magic so you still need to watch your diet.
    hispanic mechanic
    Reputation: sslos's Avatar
    Quote Originally Posted by Walt View Post
    -Walt
    Dude. Uncomfortable imagery...
    Los
    Whiskey is my yoga.
    dongerparty.com
    Out spokin'
    Dec 1999
    Thanks.....
    You'll lose a little weight off the bike but gain 110 lbs of fit, attractive, new brunette GF who loves to 'ride' as much as you do.
    =S
    disciplesofdirt.org
    Gigantic Hawk
    Reputation: dubthang's Avatar
    Quote Originally Posted by Sparticus View Post
    =S
    This is completely false.
    Mine's a blonde.
    Reputation: Andy R's Avatar
    Nov 2008
    =S
    So when exactly is this due to happen? I'm still waiting......
    Reputation: rob1035's Avatar
    ~1lb. Someone had to throw a number out there
    Reputation: Brewtality's Avatar
    I don't know about parts. You will gain 12 - 22ozs of tasty beer, a required part of any proper SS ride.
    Its all Shits and Giggles until somebody Giggles and Shits
    It's simple math really, and kind of silly that you asked people who don't know your exact situation an arbitrary question.
    I shouldn't have to explain this but... weigh or look up the following parts... RD, cassette, shifter and cable. Take that number and subtract the weight of the cog and wolla! Assuming that the chain reduction and hub are negligible or not will be based on what you are upgrading from and to. You are the one doing the math not me.
  1. Ti Bolts for Rotor - Weight Saving?
    By phlegm in forum Weight Weenies
    Last Post: 05-18-2014, 06:53 PM
  2. Niner A9C Single Speed frame weight?
    By kbike01 in forum Weight Weenies
    Last Post: 02-03-2013, 01:55 PM
  3. Best price to weight saving ratio parts ?
    By David C in forum Weight Weenies
    Last Post: 08-23-2011, 02:28 AM
  4. Replies: 7
    Last Post: 05-14-2011, 01:38 AM
  5. MBA recommends saving weight by switching top caps?
    By arrover in forum Weight Weenies
    Last Post: 03-10-2011, 07:33 PM
