Results 1 to 3 of 3
Thread: Turbine SS?
    Feb 2005
    Turbine SS?
    Hi there,
    Im considering sending my Ala Carte down the SS route, and ive been eyeing off some cheap race face 4 bolt turbines at my lbs.
    Would i be right that i can set these up with say a 34 T chainring where the middle chainring is and with a bashguard where the big ring goes?
    im pretty sure these are the cranks before the deus crankset, so im assuming a 110 BCD?
    sorry if im a little clueless,
    cheers,
    wil
    Combat Wombat
    Reputation: BrianU's Avatar
    No problem.
    Quote Originally Posted by Little Willy
    Hi there,
    cheers,
    wil
    I have done just what you are asking on two different cranks and you will want a 104 BCD on a 4 bolt.
    Brian
    SUBLIM8er
    Reputation: Axis II's Avatar
    I ran the 5 bolt Turbine ISIS and now the Next LP ISIS on my SS 29er. 32 tooth CR on both. This is a bullit proof setup and STIF. Do yourself a favor and get a Blackspire Mono Veloce CR for it. You won't be disappointed.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
