Results 1 to 7 of 7
    Sep 2012
    Track end chain length?
    How do you find the right chain length for track ends?
    Should I push the wheel all the way in, cut the chain as close as possible and then pull the wheel back to get the slack out?
    Let me know if this is how its done. Before I put the wheel about mid way and then pulled back but I am having trouble popping a wheelie so want to tuck it in
    TMANIAC
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Quote Originally Posted by TManiac View Post
    That's the way I did it on my slider equipped bike.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Sep 2012
    Quote Originally Posted by wv_bob View Post
    Cool, thanks wv_bob.
    Pretty much. Make sure you have enough length to derail the chain, so you can remove the wheel.
    ^^ good point. It's been a while since I had a bike with track ends.
    Eli Broccoli
    Reputation: 123elizxcvbnm's Avatar
    I like to measure that then if your length can handle it, add a link set. This way if I break a chain on the trail I have enough to patch it back together.
    Sep 2012
    Yeah, I cut the chain for mid position and went back from there so I could get the chain off easy. I always use KMCs with the reusable link so I'll probably go all the way in + a link next time.
    Thanks everyone, good tips.
    TMANIAC
  1. Help with chain-ring size vs. chain length...
    By firstRWD in forum Singlespeed
    Last Post: 04-20-2013, 09:33 PM
  2. Chain Length
    By austin_bike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2012, 08:38 PM
  3. 2012 S-Works Epic proper chain length. (new chain)
    By EpicFSR in forum Specialized
    Last Post: 07-26-2012, 01:53 AM
  4. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  5. chain length
    By jrafter in forum Singlespeed
    Last Post: 02-18-2011, 01:07 PM
