Results 1 to 6 of 6
    DIRT FIEND
    Feb 2005
    Total noob question
    I apologize for this totally lame noob question. How do disk brakes work on a horizontal dropout singlespeed(no smartass answers please)? How can u take the wheel on and off? Please, no flaming.
    thanks
    EAST*BAY RIDERS UNION //REPPIN DA CASTRO TO THE VALLEY YAY AREA\\
    my place of occupation EDEN BICYCLES
    WE BE DEALIN...
    GIANTS
    ELLSWORTH
    ROAD STUFF LIKE LOOK PINARELLO BIANCHI BLAH BLAH BLAH
    blame me for missed rides
    Reputation: weather's Avatar
    read the faq.
    DIRT FIEND
    Feb 2005
    Here
    This is what I am talking about
    http://bianchiusa.com/typo3temp/81c4362b59.jpg
    If I got this bianchi G.U.S.S would I be able to take the rear wheel off if I flat on a trail. Is there something on this bike that alows easy removal of the rear wheel without having to remove the rear disk brake caliper?
    WE BE DEALIN...
    GIANTS
    ELLSWORTH
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    My Surly Karate Monkey seems to be similar. With my Formula 4Racing, I had to loosen one, and remove a second caliper bolt.
    Not all calipers sit at the same angle, thus apparently some brakes did not require any adjustment for wheel removal. I'm not sure which. However, if you find a rotor with "bites" taken from the edge, I've heard that those bites can be used for easy wheel removal. Set the bite over on the edge of the caliper and voila. I also wouldn't know for which rotor/caliper/frame it would that way.
    when my 4Racing went back for maintenance, I swapped to a rear V, and never looked back. Lighter, simpler, easier to maintain and adjust. Horizontal dropouts take enough of my skills and patience for wheel removals, even without discs.
    Reputation: brant's Avatar
    Quote Originally Posted by breggurns
    You don't need to remove the caliper. Just remove a bolt, loosen the other one, and swing the caliper up a little.
    No problem with Avids. Can be problematic if you have shims to align your disc brake.
    The other downside is the force reaction from the disc brake can cause the rear wheel to move backwards on the disc side - a direction that isn't resisted by the chaintug.
    I've seen this happen on Spot frames, and heard about it on Surly's.
    A good skewer helps though.
    On my Surly 1x1,I have to remove 1 bolt and loosen the other to rotate the caliper (Avid mech.)to remove the wheel.I've never found it to be a problem.
  1. Disciples of trail work
    By General Coonskins in forum Oregon
    Last Post: 04-26-2004, 06:20 PM
  2. Disciples of Trail Work
    By General Coonskins in forum Singlespeed
    Last Post: 03-23-2004, 09:49 AM
  3. Disciples of Dirt-Oregon trail work
    By General Coonskins in forum Trail Building and Advocacy
    Last Post: 03-23-2004, 09:43 AM
  4. Disciples of Trail Work-Oregon
    By General Coonskins in forum Endurance XC Racing
    Last Post: 03-23-2004, 09:39 AM
