Results 1 to 28 of 28
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Too old and set in my ways, I guess....
    Would someone please splane to me how pictures are posted on the new board? Is it simply a matter of clicking the "Manage Attachments" link below, selecting the attachments and clicking send?
    How about adding text between the pictures? Same as the old board w/ img src html? How do you know what file name, etc. is used?
    Aarggghhhh!! Change is good, but I'm too stupid to figure this out on my own.
    Ken
    Test:
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Let me help....
    Old message board = simple, easy, logical.
    New message board = complex, difficult, illogical.
    But it sure is snazzy!
    That's it as far as my technical know-how. I'm surprised I got my avitar up....
    My post is that way --->
    Hmmm. I'm pretty sure that is all I did. For the single pic, I mean. But the pic didn't show up in the preview - only when I posted furreal.
    Wibble
    34N 118W
    Reputation: Hollywood's Avatar
    so far...
    all of the multiple pics I've seen are hosted offline on another server i.e. their own, not mtbr. I'm still working on that one as well.
    Francis has a post in the General/Help board that may offer some insight. Scroll down a ways.
    good luck to us all,
    HW
    Quote Originally Posted by Ken in KC
    Ken
    Test:
    Reputation: Brandon's Avatar
    Sucess! The secret Lies in the edit function......
    Testing pictures...
    Text between the pictures...
    Ok.. So it is possible.. But it's a pain in the arse...
    nore testing...
    Aww.. Aren't they Cute...
    Not so cute.. just testing...
    Again.. Not very cute...
    I know how to .....
    Make it look like this:
    Then the Second Picture...
    No magic involved... but it does take more steps than the old system...
    First... Create a post and attach all your images.. put in a pointless message like
    "placeholder for message to be added on edit"
    Then post it...
    Find the first file attached line and right-click on the link and select properties.. it will look something like this:
    http://forums.mtbr.com/attachment.php?attachmentid=380
    And the second picture would look like...
    http://forums.mtbr.com/attachment.php?attachmentid=381
    Save all these into your notepad (prefered) or write them down
    Then re-edit the message and use the Insert Picture button to add each picture where you want it (paste the url you got above into the box).
    Your message will still have the "so and so has attached the folowing files" at the bottom.
    3D guy
    Reputation: gstahl's Avatar
    If the image is already on the web I was successfull with (less than)img src="URL"(greater than) for multiple images in a post.
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by Brandon
    Is that you don't know the url of the pictures you've attached until after you've submitted your post. It would be nice if the upload window included the url text like the old message board did for each uploaded file.
    You can use the "upload photos" link up in the top right to upload images just like old system. Copy and paste the URLs from there into the img src tags.
    His problem..
    Quote Originally Posted by gstahl
    Here goes....
    Quote Originally Posted by Mine'sAPint
    this is an official attempt to post a picture on an internet message board... this is my wife's 1x1 after I secretly attached a fork that has no travel whatsoever...she loves it...
    <img src="http://gallery.consumerreview.com/webcrossing/images/1x1girlrigidset-up.jpg" border=3>
    Paintbucket
    I've been using ubb image tags, which go like this:
    First upload your image to a server (MTBR's or what I use [its free], imagestation.com). Then copy and paste the full url between image tags like these, leaving out the space between "[" and "img":
    [ img]http://yourimageurlhere[/img]
    Works for me, although I'm not sure it can handle the parentheses the MTBR server puts into some urls. I know it can't on other boards.
    Zippy for president
    Medium?
    Reputation: Fast Eddy's Avatar
    You just need to...
    ...wait until I figure it out. Here's an avatar, inline using normal "img" html tags.
    <img src=http://forums.mtbr.com/image.php?userid=234043&dateline=1073347350>
    and here's my attachment, using this url:
    http://forums.mtbr.com/attachment.ph...ntid=425&stc=1
    <img src="http://forums.mtbr.com/attachment.php?attachmentid=425&stc=1">
    What I can't figure out is how to get the url before you post the post. You probably can't. You can do the post with attachments, then edit it to look the way you want, but that would be kind of a pain.
    <br>
    Medium?
    No, you can remove the attachments after...
    ...you edit, and the "so and so has attached..." message goes away. See my post above. I made it using your method before I read your post, and removed my attachment after.
    So I'll try this...
    **** it. I give up. No more pictures from me, I guess.
    Ken
    Last attempt...
    Ken
    Des(s)ert Rat
    Reputation: screampint's Avatar
    Dec 2001
    Are you trying to do this?
    Ken
    Des(s)ert Rat
    Dec 2001
    Mystery....
    Quote Originally Posted by screampint
    It works in the other threads... Hmmmm... Let me try something.
    <IMG SRC="http://gallery.consumerreview.com/webcrossing/images/9doesntsuck(1).jpg">
    semi-evolved simian
    Ken
    Ken, apparently it barfs on the () brackets I had the same problem and eventually got it to work using < img src="http://blahblah/" > (without the spaces). Hope that helps you a bit.
    Des(s)ert Rat
    Dec 2001
    Ok
    I typed (IMG SRC=""http://gallery.consumerreview.com/we...sntsuck(1).jpg) but I used the little >< signs instead of the )(
    DAS
    DAS is offline
    Reputation: DAS's Avatar
    Good job! New Board? Cool!
    Wow, I had no idea there was a new forum tool. Very cool. Looks like a super cool Linux board, not that I would know (closet nerd).
    Need to figure out how to get my signature set up...
    DAS
    Member since 1998!
    DAS
    DAS is offline
    Testing again
    Let's see if I figured out the Avatar thing.
    DAS
    Thanks for the coaching, Sar...
    One more time....
    <img src="http://gallery.consumerreview.com/webcrossing/images/2fromthefront(1).jpg">
    Ken
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    The above posted with [ img] and [ /img], without spaces of course. Below, the image is posted with the < img src= version.
    <img src="http://slipstream.student.utwente.nl/picserver2003/getimage.php/F8384E10/ps_SS926.jpg">
    I guess I didn't know that posting pics was such a pia. After learning to post multiple pics on the old board, its kinda become an easy thing to do anywhere, especailly once you learn the tagging that you need to use. I do know for sure that the [img] brackets can't use (_) in the address of the picture. Screws it up somehow or other. You get the parentheses if you load multiple copies of the pic into mtbr's server.
    Just a regular guy.
    get down!
    Reputation: appleSSeed's Avatar
    is that a 29er Hunter? looks great!
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    rbtm member
    Cool bike!
    this looks like a good place to post tests.....
    Witty McWitterson
    yes, t'is. I've had it for 2½ yrs and am loving it more every day. Its been a great ride for shizzle. If you're looking for a custom, I highly recommend Rick. Easy to work with. Good prices. You're in the KC area, right? I'd like to get down there at some point, maybe you could even see it up close!
    Just a regular guy.
    Perhaps at the Summit?
    Quote Originally Posted by ~martini~
    The Summit for 2004 will be on March 19-21. Meetings on Friday, Racing and Festival on Saturday and another race on Sunday.
    That would be a great tiem to meet up and ride....
    Ken
