Results 1 to 5 of 5
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    Titanium question
    I was wondering if you guys know if titanium gets to a stress point will it bend or will it crack in half?
    "If women don't find handsome , they should at least find you handy."-Red Green
    Titanium tends to flex easily. It is a little more elastic than steel. As you put it through stress cycles where it flexes it will either become brittle and crack or bend permanently. If it has an area that acts as a stress riser it is likely to crack. Take a material science course. It's very interesting. It's been too many years since I took mine.
    well, if you mean 'will hucking stairs on a Ti road bike be bad for it?' yes, it can break and bend like any other material. It tends to bend a lot before it cracks though, and can be bent back easily enough. Bend it back and forward a lot of times and it will break. Ti is more suceptable to notch type failures than many other metals. This means that a deep scratch becomes a serious stress riser and is likely to be a failure point.
    Kosher Princess
    Reputation: Natalie Portman's Avatar
    Good job!
    Kosher Princess
    Good job!
