Results 1 to 32 of 32
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Tips on trueing rotors...anyone?
    I know there are some shadetree mechanics around here who've got some MacGyver-esque method of making flat again what had been made wobbly.
    I tried the caveman approach, just using some vice-grips, with no luck.
    Any hot tips?
    Penis Goat!
    Reputation: GirchyGirchy's Avatar
    I just use a small or medium (6"-8") adjustable wrench, open slightly larger than the width of the rotor, not clamped to it. I keep the wheel on the bike, which is upside-down, and run it through to see where it needs adjusting. Then I pull the problem section in the opposite direction, using the wrench, and I keep on until it's pretty true. It's worked fine for me.
    Quote Originally Posted by GirchyGirchy
    Cool, I'll go attempt.
    Reputation: scottms33's Avatar
    no vice grips
    clamping on it with a vice grip could leave a bur on the roter. that could make things worse. is it really that bad, i never did it to my hayes brakes the 2 years i had them...
    scott
    I am the owl
    Reputation: riderx's Avatar
    Small adjustable wrench and a pencil. Stare down the rotor, slowly spin the wheel until you either don't see light between the rotor and the pad OR you hear the pad contact the rotor. Mark with pencil, tweek with wrench. Repeat as necessary.
    SingleSpeedOutlaw .com
    Riding Bikes and Drinking Beer.
    Just Ride!
    Reputation: kustomz's Avatar
    In the past I have taken a piece of 1x2 wood about 12" long and cut a slot in it with a skill saw. Just use this as a lever, the wood is gentle on the rotor.
    err, 27.5+
    Reputation: AL29er's Avatar
    Crescent wrench or one of the old school brake alignment tools. The brake tools are about the same as the disc specific tools. I am more of the use what you got opinion on straightening rotors since it isn't a task that needs to be tackled too often.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Quote Originally Posted by Padre
    Any hot tips?
    Bicycle Research makes a tool (LC-1), that is designed to straighten chainwheels. I have found that it works great on rotors. I have also tried the the adjustable wrench trick. I have used both tools at the same time, too. Good luck.
    Todd............. If you can't be kind, at least have the decency to be vague
    This place is a verifiable bastion of quality mechanical info.
    Thanks gents.
    I've tried the crescent wrench approach already tonight.
    I had already pulled the rotor of the wheel, so determining where is was out was a bit tougher.
    I'll reinstall it on a wheel to get a better view.
    Kudos!
    meatier showers
    Dec 1999
    I can't believe it
    Nobody said to use your bare hands? Amazing. That's what I always do. Rotors are extremely malleable. It doesn't take much pushin' to make 'em perfect again. I leave my bike in the stand and use the caliper as a runout gauge. Personally, I'd never put a metal device around my rotor and tweak it thataway... it seems like I'd be much more likely to bend the rotor in the plane between brake track and rotor bolts. Whenever I use my bare hands to eliminate rotor wobble, I'm confident the adjustment in rotor warp is occurring at the hub, rather than the next weakest place -- where the rotor spokes meet the brake track. I've straightened my rotors infrequently over the past 4-5 years and have yet to be disappointed in the bare hands method.
    --Sparty
    disciplesofdirt.org
    intentionally left blank
    Reputation: Adrian's Avatar
    --Sparty
    my understanding is that you never touch rotors with your bare hands - unless you hit them with rubbing alocohol and burn that off afterwards.
    i guess that's more of a priority for the pads, but it stands to reason that you'd apply that to the rotors too.
    SS Grrrrrrrl
    Reputation: dirtcrab's Avatar
    I second this approach. I use it all the time. Be sure to wipe the wrench arms with rubbing alcohol prior to using and it's probably not a bad idea to wipe down the rotor with rubbing alcohol when you're all done trueing.
    Medium?
    Reputation: Fast Eddy's Avatar
    A story
    My son and I were fooling around on bikes at the school, and I dropped off the right side of a concrete wall and "landed" on my 7" avid rotor on top of the wall. It was bent taco-style at about 75 degrees. I had to walk home thinking about the $50 it would cost to recover.
    A couple hours later I was unpissed enough to take another look at it, take it off the wheel, and start whacking it with a 5 lb sledge hammer. With that as an anvil, and a framing hammer I got it pretty straight. With another hour of work on and off the wheel I got it straight enough to ride.
    I've been riding it ever since.
    It rubs a tiny bit in my Hayes caliper, but the Avid caliper has enough throw to miss it completely. I tweak it sometimes with a crescent wrench if it needs it. I don't bother wiping or alcohol. I'm pretty sure that "don't ever touch your rotors with your bare hands" thing is overstated.
    I am the owl
    Quote Originally Posted by Fast Eddy
    Well, I wouldn't touch it after you've been riding, especially downhill! But for reasons other than those stated above.
    Cold. Blue. Steel.
    Reputation: OneGearGuy's Avatar
    except...
    Quote Originally Posted by dirtcrab
    Avid recommends that you don't use alcohol on their rotors because their pad compound makes an awfull squealing sound if you do (i have personally heard it! ).
    but clean tools and hands are a must.
    Spinning and Grinning...
    Its only 1" on the map!
    Reputation: mtbbill's Avatar
    Quote Originally Posted by riderx
    I have used the same approach but with two wrench one to tweak with and the other about 45 degrees away to isolate the torque to the area I am working on.
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by OneGearGuy
    That explains a LOT. Nothing quite like the "symphony" of front and back Avids producing slightly different pitched squeals. Urghh. Mind you, it does stop me using the brakes quite so much, which is possibly a good thing
    SS Grrrrrrrl
    Interesting. It causes no such noises on my Magura Marta's.
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Greasy fingers
    Quote Originally Posted by Adrian
    I'm not sure how much a fingerprint would degrade performance (unless said finger had gone directly from the peanut butter jar to the rotor). I eat a lotta PB, so I use a clean shop rag when I work on my rotors. I've gotten better results using finger pressure (just small nudges, not trying to get it all the first time) than I have with the wrench method, which seems a little like trying to true a wheel by just working on the worst spoke.
    Medium?
    Why not?
    <center><img src="http://gallery.consumerreview.com/webcrossing/images/136_3629FC.jpg">
    Photo credit: Biking Viking</center>
    I am the owl
    Sweet photo.
    meatier showers
    Dec 1999
    The defense rests
    Quaffi baby, you said it perfectly.
    Avoiding the best method to true a rotor for fear it might get a bit of oil on it would be like buying a new car and parking it in the garage forever and throwing the keys away because driving it would cause it to wear out.
    I always wash my hands before I manipulate a bent rotor. In the four + years I've used my hands to true my rotors, residual body oil has never proved a problem. Seems to me that anyone riding up and down serious hills would burn the body oil off within a few minutes of descending anyway. That is, unless they have a real sweating problem I suppose.
    --Sparty
    Quote Originally Posted by quaffimodo
    disciplesofdirt.org
    DAS
    DAS is offline
    Reputation: DAS's Avatar
    crescent wrench
    I always had trouble adjusting the rotor by hand. I started using a crescent wrench and got them to true up nicely.
    also, all the out of true problems I've had with my rotors have been to shipping the bike, as in packing it up in a bike box. So I would advise whoever is listening (no one?) to be extra careful while packing up disc wheels.
    meatier showers
    Dec 1999
    You're right, DAS
    Okay so the car analogy was a medeocre one, I admit that. It would be more appropriate to analogize it to throwing the baby out with the bath water.
    Besides, DAS, your experience with tools and bike repair are legendary here on MTBR.
    Hmmm... shipping my bike... something I've never done and never intend to do. Sounds to me like it's asking for trouble.
    --Sparty
    Quote Originally Posted by DAS
    disciplesofdirt.org
    Penis Goat!
    That may be, but all I know is that last year, I rode my bike onto campus for a little while. I could do nose wheelies no problem on the way there. When I got there, a friend decided to start grabbing ahold of my brake rotor. On the way home, I couldn't lock the front brake.
    After taking the pads to work and having a friend torch them with an oxy-acetylene torch, they worked great. I can perform nose wheelies once again.
    That's my story, and I'm stickin' to it!
    ali'i hua
    Reputation: SlowSSer's Avatar
    Sweet photo.
    my sentiments exactly.
    but the hissing sound of water droplets on hot discs is so cool!
    Sweet photo.
    No kidding! Hot!
    meatier showers
    Dec 1999
    No argument from me
    I agree with you 100%.
    When I said "residual body oil has never proved a problem" I didn't mean that it has no effect. Just that it's not problematic. I don't often do nose wheelies when I'm flyin' down a singletrack (not on purpose, anyway ) and besides, whatever RBO (residual body oil) that exists on the rotor quickly vaporizes when the rotor gets hot. Some might say that the oil gets heat-infused into the pad and that may be true, but if it is, an insignificant amount of RBO has never seemed to degrade the performance of my brakes.
    Another story worth stickin' to, IMO.
    --Sparty
    disciplesofdirt.org
    Medium?
    I like the smell of the mud burning. It remind me of four-wheeling when I was a kid.
    Cold. Blue. Steel.
    Avid only...
    exactly. they are Magura's...
    seems only to effect Avids pads. don't really know why. confused:
    just know it does. :
    Use Rubber Malet
    I start with an adjustable wrench. Then I use a flat wood board and a rubber malet. It leaves no marks on the rotor. I lay the board on a concrete driveway or sidewalk as support and bang the rotor gently back into shape.
    190lbs of climber
    Reputation: Menso's Avatar
    Bare Hands
    You don't need to worry about getting any oil on the rotor if you just hold a piece of cloth (clean rag or something) while bending it back. It's like the bare hands method, just not bare, and nobody can whine about it.
    ye' old trailblog: www.most-excellent-adventures.com THE BAY AREA... WHERE IF IT'S FUN, IT'S ILLEGAL
  1. a2z rotors?
    By FoShizzle in forum Brake Time
    Last Post: 12-09-2004, 06:37 AM
  2. Up-sizing Shimano XT rotors to 180 or 200 mm
    By Dave99 in forum Brake Time
    Last Post: 09-22-2004, 11:36 AM
  3. Replies: 1
    Last Post: 08-17-2004, 05:54 PM
  4. 180+ mm rotors and Fox Warranty
    By sliderhouserules in forum Shocks and Suspension
    Last Post: 05-03-2004, 04:39 PM
  5. Ceramic coated discs?
    By Tony Montana in forum Brake Time
    Last Post: 03-17-2004, 07:21 AM
