Results 1 to 59 of 59
    DFMBA.org
    Reputation: MTBeing's Avatar
    Tips/tricks for SS sustained climbing?
    I'm just getting into this, and rode this past weekend up some steep-ish, non-techie switchbacks. My body tells me when to stand and mash, versus sit n' spin, but I was wondering if there's some advice the experienced singlespeeders could chime in here. Are there any tips/tricks to steeper climbs, especially when you're in the thick of the climb and trying to keep from stalling out. What are your strategies for maintaining sustained climbs? Thanks.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Do everything you can to maintain momentum.
    Don't back off...
    SPP
    Rigid.
    nothing to see here
    Reputation: Stevob's Avatar
    Like SPP says, momentum is the key. Keep it going from the bottom of the climb. Don't start slow and try to save yourself for the steepest parts. Deep breaths and recover as much as possible when it levels (if at all). Keep weight on rear tyre to avoid slipping. You can ride anything on a SS that a geared bike can, given the right gearing. Choose wisely.
    Rinse and repeat.
    I see hills.
    I want to climb them.
    Gotta pay to play
    Reputation: michaelscott's Avatar
    I wrote an post a few months about about Newton's 2nd law Force = Mass x Acceleration. Since we have no gears there is no way for us to slow down the bike. Therefore we can't really reduce Acceleration. This means we are stuck with a base amount of Force that we have to exert or the bike will stall out. Often times this Force we have to consistently exert to keep the bike from stalling is greater than the VO2 we can hold for the length of the climb. So when riding up a hill either one of three scenarios will happen:
    1) You'll run out of oxygen (hit your VO2 Max limit) and have to get off the bike. In other words- your fitness couldn't keep up with the speed you were pedaling up the hill.
    2) You'll stall out (too hard to pedal) or spin a wheel. You were going too slow. Either because you were trying to conserve your Oxygen or because your fitness isn't there to spin the bike fast enough (which is slightly different than #1. I've had times where I wasn't breathing very hard but I just didn't have the speed or strength to make it up- I should have been going faster.)
    3) You'll make it up the hill. Your fitness allowed you to push the bike at Force greater than or Equal to the mass of your bike (and the slope) times the minimum speed you pedaled the bike up the hill.
    For sustained climbs you have to think like a geared rider and try to go as slow as you possibly can without stalling out. This will keep your heart rate down, keep you from going into Oxygen Debit, and get you though the climb as long as you can keep from stalling or slipping the rear wheel.
    Your fitness level will automatically go up the more you ride SS. Just try to hit those short climbs as hard as you can to increase your leg strength and VO2 max.
    Anyways TL: DR version: Go as slow as you possibly can without stalling or slipping.
    DFMBA.org
    Thanks for all the responses. I found myself leaning forward almost to the point of losing traction in the rear wheel, then backing off to maintain it. The cool thing I realized is that power txfer feels so deliberate. Standing and mashing on a SS feels different than a geared bike. I was wondering if there was a 'trick' to capitalize on this great power txfer (e.g. deliberately shifting weight, rocking side to side, etc) to enhance momentum. Maybe I'm over- thinking this.
    Phobia of petting zoos.
    Momentum is your friend and lover but it can be hard to maintain that on long sustained climbing efforts.
    Take a look at your chainring, it's round. Don't forget that! Your pedaling motion should aim to keep power through the whole circle. Don't stamp down and expect that to get you there (unless you're riding one of those goofy old Alenax bikes - google them if you don't know what I mean).
    Despite your best efforts to maintain that circle there will still be a dead spot. Get into the rhythm of rocking the bike forward through the dead spot in your pedal stroke. And yeah, rocking the bike from side to side is useful too. Wider bars give some leverage for that.
    Well, the above works for me, give it a shot and see if it helps.
    Oh, and don't let it get to you. Think happy thoughts. If you start to focus on any pain or how long it's taking, or how you long for something for your right thumb to press then before you know you'll be off the bike and having a hissy fit like a 13 year old girl who missed out on Bieber tickets.
    Grumps
    Jan 2011
    Often in a long race and/or a long ride walking super steep sections is a better tactic. If your speed falls below around 4mph you might as well walk the steep section and resume riding when the terrain allows. Most long climbs only have a few steep sections and as such sometimes walking short bits is a good idea.
    For long climbs adding bar ends helps give you a more powerful and relaxed climbing position. Also select the gear that works for your riding area. My view is that the best gear one that works well for the majority of the day. Some of the time it will be too low and sometimes it will be too high. If you are in a hilly area you will need to pick the gear that works well for climbs and then simply coast the downhills and go mellow on the flats.
    Reputation: ChaosCelt's Avatar
    Feb 2013
    When you stand up and mash down on the pedals alot of people have the tendency to unweight the rear wheel...that's bad and as sucks here due to how slick our trails stay. When my uncle was teaching me to climb he kept telling me "kiss the headset". That kept me up and in a position to really use my legs but also allowed me to add in the arms like Uncle Grumpy said, all while keeping my rear wheel planted. I see alot of riders here that are hanging WAY over their bars on the climbs we have.
    Just keep turning the pedals.
    (michaelscott) "For sustained climbs... try to go as slow as possible without stalling out. This will keep your heart rate down, keep you from going into Oxygen Debit, and get you though the climb as long as you can keep from stalling or slipping the rear wheel."
    For me ^ this works, plus generating momentum, so that on any flat spot I can coast or spin without pressure. Doing so keeps my breathing in check, and saves some punch for those steep sections.
    Notice that with a smaller cog, one can generate more uphill momentum, yet it taxes both aerobic capacity & leg strength that will either crush you, or enables you to kill it.
    Mar 2006
    Quote Originally Posted by Flyin_W View Post
    Well said.
    Totally agree.
    SPP
    Rigid.
    Use momentum to try to find the sweet spot for the gear your using, if not doable learn to ride real slow with a ultra low cadence. The sweet spot to me is when I can maintain speed without my HR going up too fast. To manage energy on really long climbs I try to master the seated climb, if I stand too much my HR goes ballistic. Mastering a real slow cadence/speed uphill helps avoid unclipping and causing a hill start or walking. This is handy in races when stuck behind other riders climbing slow (usually in the little ring) and you need to almost track stand mid climb to avoid the dreaded unclip which usually leads to running or walking it out.
    Apr 2013
    All great advice. I'm just starting too, and this helps, especially the 'kiss the headset' guideline. I've lost the back tire a couple times, stopping my momentum and forcing me to walk.
    Wide bars help for the slow leverage just at the top of the climb to get you over that last hump.
    I also like the slow rhythmic cadence that you can develop while standing not sitting, my knees don't like it when I sit and mash.
    Lastly, when I get a chance on those slight 'breaks' and I'm riding alone, or not in a hurry, I will "practice my trackstand", aka "lower my heart rate, and take a breather".
    I thought I hated climbing, but writing this, makes me want to ride. Or maybe I just don't want to be at work...
    Reputation: serious's Avatar
    Jan 2005
    Quote Originally Posted by michaelscott View Post
    No, no, no! Go as fast as you possibly can to keep momentum.
    With experience you will realize just how wrong your advice is.
    My rides:
    Lynskey Ti Pro29 SL singlespeed
    KHS Team 29
    S-Works Roubaix SL3 Dura Ace
    KHS CX 550 cyclocross
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by serious View Post
    The OP was asking about sustained climbing. Maintaining momentum is good advice on short efforts but on a long run nobody can redline forever, and while I don't completely agree with the advice to go as slow as you possibly can I think there is a balance somewhere in the middle, or as dwilson said- "find your sweet spot".
    Long, sustained climbs often have little chunks here and there that are steep and/or techie and you need to have something in reserve to handle those parts, and to have some gas in the tank for the rest of the ride.
    too late to die young now
    Reputation: Felton_Flyer's Avatar
    Dec 2008
    For me - slowing cadence to expend the least amount of energy while maintaining balance and forward motion. Always attack a climb at the bottom and settle into a variety of other methods as laid out below..
    When my legs start screaming and begin to fail on long, sustained climbs I resort to different methods (in no particular order):
    1. The 'hurky-jerky' method of lunging the bike forward to get over a steep spot.
    2. The 'traverse' method of moving left to right over the hill while recovering (admittedly, not pretty - but effective).
    3. The 'seated' method of attempting to grind out a long climb using as little energy as possible while keeping some forward momentum.
    To each their own, but I find riding spuds can help recovery on long grinders as I can switch from using solely downward pressure on the cranks to using upward strokes on the pedals while clipped in. This uses different muscles and enhances recovery and oxygen transport to the tired muscles.
    I go through a kind of cost-benefit analysis at some point on a long climb - is it better to walk up and save some legs for later or better to continue and grind through? This also depends on my mental tenacity ... some days the anger from my legs screaming to 'STOP' will piss me off to the point that I can dig deeper and pull off a climb. (Those are good days indeed =)
    \sigma_T\sigma_x \geq \tfrac{\hbar}{2m} \left|\left\langle p_x\right\rangle\right|.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Quote Originally Posted by c_m_shooter View Post
    +1.
    Use your calves to rest your thighs a little.
    I ride with the best dogs.
    One trick I use is weight distribution. I try to climb in a standing position that balances my weight front to rear in such a way that if I lean back, I increase grip. If I lean forward, I decrease grip. What this does is allow me to slip the rear tire slightly when needed. This is like hitting a lower gear breifly and can get you out of a jam and keep from stalling.
    Jan 2005
    Quote Originally Posted by J.B. Weld View Post
    Going as fast as you can does not mean redlining. Weather the climb is 20 seconds or 20 minutes, going as fast as you can for that period, it what we aim for. Nobody aims to ride as slow as they can. Well, not if performance is part of the equation.
    My rides:
    KHS Team 29
    Reputation: ZTallboy's Avatar
    May 2012
    Vision, line & pedal efficiency!
    Reputation: 4nbstd's Avatar
    I do it all, but I don't think I ever sit down on any climb. First I'll stand and start pedalling, then start smashing, then lean forward... I run 32/20, and while it's hard to keep momentum at the beginning with that ratio, I find it's easier to keep it moving when I don't have the momentum anymore. 32/18, had better momentum at the beginning, but when I'm out of gas and barely moving, it's hard to keep the bike moving.
    Ghisallo Wheels
    I'm really good looking.
    If I go as fast as I can for a 20 minute hill climb that is called a time trial, and if your ride ends there then that strategy works fine. The ride usually doesn't end there though so most mortals have to pace themselves up a long climb, and throughout the whole ride in order to maintain the fastest average speed. Riding a single speed can make pacing a climb more difficult because you are not always in an ideal gear. You have to adapt.
    A lot of good advice here.
    One thing I do is what I call "dance". I use quite a bit of body motion to sort of "dance" my way up the hill. My dance enables me to rock the bike forward and backward to get over boulders. Also, I like to just hover over my seat when mashing then pop up and lean forward to get the bike over a rut or boulder. Another thing you can do is on the up stroke of the pedal, pull up with your knee. This has the effect of bringing in the hip flexor to help you. This is why many runners are excellent climbers. Running works the hip flexor (and the core). When climbing you will be using all the muscles in your body from your shoulders down to your feet. Bar ends help immensely for leverage.
    Lastly, when the hill begins to level off enough, you should sit down immediately. Sit on the nose of your seat and bend your elbows 90 degrees. Your forearms should be parallel with the ground.
    Reputation: boostin's Avatar
    You want to keep as high cadence as possible always. The higher cadence takes the bite off the grind and is actually easier than slowing down and grinding each stroke. I am not adverse to walking either.
    I gear my bike towards climbing - 32x20 on 26" wheels - so that I can get up more hills.
    May 2012
    It all comes down to how effectively you can conserve energy. As many noted, find your sweet spot, momentum is key as well as picking the best lines and maintaining focus,vision.....and confidence. The mind is a big part of the process.
    Reputation: A1an's Avatar
    Keep pedaling until you reach the top. /thread
    Signature
    Reputation: jetboy23's Avatar
    Quote Originally Posted by A1an View Post
    This.
    Honestly, i will sit, stand, mash, or walk. As long as i'm moving forward. Ideally i'll maintain the fastest pace i can while keeping my heart rate around LTH and conserve maxing for the shorter steeps. I'll do this for any climbs ranging from 15 minutes to an hour. More than that and i'll work in walking for the steeps to decrease the amount i max. I'm still learning that fine line though and sometimes blow up from being too pedal happy.
    Find your happy place and turn those cranks. When you get tired, breath, then start back up the hill again until you get tired. Rinse, lather, repeat.
    SSolo, on your left!
    Great advice!
    Quote Originally Posted by Uncle Grumpy View Post
    Grumps
    More good stuff! Only thing I'd change is fit the bar width to your comfort, not just wider better, because when it gets tight and twisty really wide bars are slower handling and awkward. There may always be a hill you can't make without walking even if you change gearing.
    Quote Originally Posted by febikes View Post
    Yep, yep, yep.
    Agreed, especially on the last sentence.
    Quote Originally Posted by Felton_Flyer View Post
    Agreed, but I always stand when grinding out a SS climb, so I deleted option 3.
    Quote Originally Posted by TacoMan View Post
    Nice, I'll have to try that thanks for the idea!
    Quote Originally Posted by 4nbstd View Post
    I'll sit and spin before the climb (if it's a fast section), then as I lose speed I'll stand and mash when spinning is no longer efficient or effective lol.
    Get off the couch and ride!
    Abby Normal
    Reputation: Holmes's Avatar
    I usually try to think about something pleasant whilst grinding up a sustained climb, like drowning myself in beer afterwards. Sometimes that helps. Otherwise I just sort of whimper and sob quietly until I reach the top.
    Something that has seemed to help me the most with climbing is my track standing ability. Sometimes when I feel like I am going to pass out or getting into the red zone I will just back off the pressure, track stand for a second and within that second, take in the trees/birds, relax and take a deep breath, and then hit it hard again. I find that if I am grinding up a climb too much then I am more prone to stalling on tech sections or a wheel spinning out.
    Also a high poe hub helps in the track standing or either make sure that when you are ready to start again that you are in your power stroke with your dominate leg in the 1 o'clock position. A high poe hub can help you ratchet back to the power stroke position if need be.
    I think everyone who mountain bikes will find practicing track standing to be beneficial. I do it when I am farting around in the driveway with my friends and family. When I am waiting for others at the trailhead or parking lot, or when I am just hanging out after a race or whatever and instead of standing next to my bike I try to just stand on my bike. It's amazing what it can do for crash prevention and learning to stay on the bike and figure things out instead of bailing.
    It is amazing how much it has improved my mountain bike riding for a guy who doesn't generate much power and only gets to ride like 3 to 5 hours a week.
    Oaktown Honkey on Strava
    Don't forget to eat! I walked my gear bike the other day as I was crushed by previous days rides! I was glad nobody saw me, funny. But I got to the top! Sweet downhill followed since I checked my ego at the trailhead and enjoyed the day.
    NedwannaB
    Reputation: JMac47's Avatar
    As Boostin said, gearing is key also. I've been back and forth with different setups on a 650B and 29r SS of late with 34/19 on the mid size and 32/19 on the big hoops. Just put the 34/19 setup on the 29r expecting to change to a 20t rr cog later. But after riding it I think I found the best setup. Which is weird that it feels a lot better with a taller gear, basically back to a 2:1 setup that I started with on a 26" wheeled bike. Must be the longer gear inch or possibly that riding them for soooo long has just made me a stronger rider @ 55!....
    Wait whuuut, who did he tell you that!?!?....
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Quote Originally Posted by jetboy23 View Post
    This.
    Don't look up.
    Jun 2013
    Quote Originally Posted by CB2 View Post
    Don't look up.
    Agree with this on long climbs. I'm a big advocate of always looking ahead down the trail and not staring five feet in front of your bike. But if it's a climb I've done a few times in the past and I know that there is nothing tricky that's gonna stuff me on the way up, I just keep my head down and dig. Looking up to the top of the hill and knowing exactly how much further I have to go can sometimes be discouraging and makes me think about giving up the fight and walking.
    Reputation: zorro's Avatar
    Feb 2007
    I look like a injured mammel trying to hump a steel contraption with two wheels while I climb. I tend to fall into the going rather slow category keeping just enough weight on the rear tire so not to loose traction. This definitley works a ton of muscles, namely the back due to pulling on the bars. Once Colorado keeps getting drier and drier, my back will be stronger and stronger since I'm going to have to put a lot of weight on the rear tire.
    It's not how old I am, it's how old I feel - Minor Threat
    Dirt Bound
    Reputation: Joe_Re's Avatar
    Jan 2011
    I Didn't read all the reply's so I don't know if someone said this already.
    You, as a single-speed rider, will climb faster than most geared riders (mostly because you don't have a choice) so leave a little room as you approach a hill on a group ride. You will get slowed down by someone or something so learn to balance at very slow speeds and how to throw your weight forward and upward. It's like doing a bunny-hop/j-hop from a stand-still. Along those lines, the track stand and a subsequent flick of the bike in either direction, while looking cool is a useful trick to re-position yourself, take a breath and focus. And yes, keep your momentum... ...every bit you muster.
    For really steep grades, track standing is an essential skill. It isn't that you need to purposefully stop. Instead, it is because balancing becomes more difficult at slow speeds. This is compounded by a single speed. If you ride singlespeed for a long time, you will be able to track stand indefinitely.
    For steep, slow climbs, it is sometimes necessary to backpedal a bit to get over a root or rock without a pedal strike. When that happens, the bike can actually roll backward a couple inches while getting repositioned. With really really steep climbs, it can be necessary to nearly trackstand between each pedal stroke.
    Reputation: raganwald's Avatar
    Someone just starting out should definitely stick to round chainrings and learn to use them properly, but the more experienced riders may want to look into something like Q-Rings, they make a nice 34T for single speeding, and it can help with climbing.
    I'm new to SS but I'm finding that some steep climbs around me are too steep to ascend seated and too long to sprint up...The result is a very slow standing rhythm where the force required to turn the pedals exceeds body weight. At this point you are pulling up very hard on the handlebars to resist each pedal stroke (feels like you are going to pull the stem off the steerer). It works ok but it really makes the pedal areas of my foot sore for a few days afterwards.
    ...I got up those climbs, though - that's the important thing!
    Hardcore Bike-Path Rider
    Reputation: Kyri's Avatar
    Rhythm, and a good song in your head.
    Bring it.
    Reputation: SoCal-Rider's Avatar
    Quote Originally Posted by jimification View Post
    Same thing I found when I first started SS. I had some clipless hiking type shoes. Too much flex. I ended up switching to a stiffer soled shoe and that helped tremendously.
    Reputation: Timon's Avatar
    then you get to the top....
    ride down 500 vertical ft, and come across another 2 mile climb....
    but you just rode as fast as you possibly can for the last hill, and burned up all your matches. now what? if you didn't manage the last hill correctly, then this one may mean walking most of the way....because that may be 'as fast as you can'. not so much fun and ultimately far slower than pacing yourself.
    i say it's all about learning your body and managing your power output vs. the slope. not every sustained climb is exactly the same gradient the whole way and you need to use the portions that aren't 100% taxing to regroup for the ones that are. and how you approach a climb at mile 2 of a 5 mile ride is gonna be way different than mile 2 of of 55, or 50 of 55.
    most steep sections just need to be attacked with a vengeance, imho. and then on the not-so-steep sections....even if standing up is still a given, everything needs to be done to get your HR back down and get yourself ready for the next kick. slow it down, get it in a rhythm where every pedal stroke or half pedal stroke corresponds with a big breath....that sorta thing. so yes, purposefully riding slow for segments or even full length climbs can be very beneficial on a long ride.
    i suppose a case could also be made for riding the flatter portions harder and simple succumbing and walking anything you deem too steep. that doesn't seem as fun/challenging to me though, albeit necessary the longer the ride becomes (or more vertical gain).
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I have the bars set at a height that allows me to extend my arms to support my upper body when climbing. I don't lock the elbows, but my arms are very near straight to ease muscle tension. My lower half is sort of hanging below me and turning the cranks in a very circular motion: slight pull at the rear position, push down at the front, forward at the top, back at the bottom and everything in between. The movement includes hip rotation, but not pulling up on the bar.
    Constant acceleration and deceleration from mashing and irregular spinning wastes a lot of energy. Try to keep your speed as stable as possible. Don't jerk the bike in any direction. Twisting the bar is another waste of effort.
    If you find the speed to be too much for you at the preferred cadence, don't worry: just slow down. Climbing slower requires less energy and will be easier even if your efficiency at a lower cadence isn't optimized.
    It seems people have different definitions for "as fast as you can". I ride everything as fast as I can but don't pass out. But you're correct, theoretically i could ride quicker. If I pushed hard enough I would pass out. There is probably something in between as well.
    That's a good SS secret. Shhh, don't tell the gear spinners. Some of us single speeders are absolutely dyeing at the top of long climbs, hunched over the bars as ping for air, head pounding. But by the time everyone else catches up, we're like what? No biggie, what took you so long?
    (edit damn iOS autocorrect)
    Quote Originally Posted by Saul Lumikko View Post
    A lot of SSers lean the bike with every pedal stroke when climbing hard. When standing this can help with the cadence by allowing a rhythm to sustain speed between each hard downward stroke. Around here the grades are steep enough that we would destroy our knees if trying to sit on the extreme climbs.
    Oct 2012
    Hard climbing is one thing. I thought the topic was sustained climbing, which is lighter but takes longer.
    I guess "sustained" also means different things to different people. Much of that is probably related to terrain and length of climbs or max elevation gain. Around here, most singlespeeders can climb anything while standing. But in more mountainous terrain with more than several hundred feet of continuous climbing, that probably isn't the norm.
    Seated climbs never seem like a challenge so it was sustained steep standing climbs that are worth discussing in this region. Sorry for the confusion.
    Keep your momentum. I did an XTerra this past weekend and there were some steeper climbs i would of made it if the geared riders did not shift down.
    Jan 2009
    Great advice from everyone!
    On my long climbs, I sit and pedal in circles and really activate the back of my legs. I get a lot of power from the glutes. When my HR gets too high, I'll stand and pedal in squares, but let gravity help and pull on the bars as needed. Standing is slower for me, but it lets me rotate the muscle groups and bring my HR down a bit. When ready, I'll sit again to pedal in circles, then stand as needed to bring the HR down.
    Dive Bomber
    Reputation: jackspade's Avatar
    My 3 years of climbing with SS:
    Use momentum, gravity, and body weight to spin the pedal not mash. If you want go faster just pedal faster not harder, use power as less as possible.
    Reputation: iceboxsteve's Avatar
    Feb 2012
    Breathe. Just breathe. Steady breaths, steady spinning, don't give up.
    A plethora of pinatas
    Reputation: mcoplea's Avatar
    Tons of great thoughts and advice in this thread! Thanks to everyone for sharing.
    I use a little bit of everything to get to the top.
    Maintain momentum to the best of my ability with out blowing up.
    Pedal in circles!
    Alternate between sitting and standing.
    Stand with a slow cadence and use my body weight to slow my HR down and catch my breath.
    Enjoy the pain and Smile! (it is hard NOT to smile when riding a SS, IMHO)
    Marty
    Dive Bomber
    One thing I forgot to mention, maintain your view to your eye level - keep it horizontal.
    By doing doing your body get's in the best form riding.
    Kaishingo
    Reputation: wuzilla's Avatar
    Didn't see this mentioned:
    Beat the geared rider down the hill, so you don't get stuck behind them go in up! Nothing worse then trying to follow someone in their granny up a hill!
    Dec 2011
    Practice trials riding. Or watch it and observe the riders body movement. I clear obstacles hillclimbing because I also trials ride. Getting over a 1 foot tall rock or root on a steep hill when you are about to stall is possible with a bar hump ass rear tire move.
    Watch trials riders body movement as they clear gaps on their rear tire and apply it to the climb.
    Find a mellow short hillclimb and climb it without pedaling. Use only your brakes and your upper body to climb it and you will get it.
    Dec 2011
    Ooo new bike trend... Chainless!
    Reputation: jscusmcvet's Avatar
    Interesting reading this morning. I am no great climber but here is what works for me.
    On a hard climb, I sometimes have to remember just to breathe :-) sounds stupid, but while under max efforts and concentrating, I sometimes find my self holding my breath.
    To enhance my breathing while standing, I try to make sure I am not hunched over but riding with a straight back, balanced enough on the bike to maintain traction with the rear wheel. I think positioning in climbing depends a lot on your particular bike set up.
    When starting a shorter climb, I am all about speed and momentum. On a longer climb I try to settle into a rythym, standing, that is not particularly fast, but smooth and steady. Being a pound it out when I need to guy, pedaling in "circles" is tough for me, but I do find better climbing by remembering to "pull up" as I mash with the other leg. As close to circles as I am going to get, I am afraid.
    The other excellent point given above is about gearing. I played around with various sized chainrings and cogs until I found the right combination. It is interesting to me that ratios with the same gear inches but different size chanrings and cogs can feel quite different on the trail and especially on the climbs.
    This is a great thread.
    On One Summer Season Single Speed
    EX-RoadLice
    Reputation: Trailice's Avatar
    Quote Originally Posted by kYLEMtnCRUZr View Post
    Not really, I have trained on DH bikes w/o a chain to learn to maximize speed on terrain, kind of like a pump track scenerio only lift assist with only manuals!
    This has helped tremendously on the ss with downhill sections, keeping up or passing geared rider.
    USB Rep'n
    Reputation: namaSSte's Avatar
    Lots of great tips and advice so I'll add two things only at this point....if you have a road bike, ride it too (not on the trails obviously). One of the best things I find for becoming a strong singlespeed rider is learning to climb well on a road bike assuming proper pedaling technique. The strength building is great and you learn about cadence better since you aren't going over roots and rock, its just ticking over the pedals repeatedly. If you don't have a road bike, then I tend to sit when I am recovering and stand when I need to. When standing, make an effort to pull the knees towards your bars. This increases the power on your upstroke and helps give a more complete rotation to your pedaling. Its not that power increases overall, its just that you are using what power you have more efficiently.
    though hope is frail, it must prevail - Taj Weekes
    betam eh-wud-eh-HA-lehu y
    eh-nay Ityopia!
  1. Etrex 30 - your tips and tricks please
    By iggs in forum GPS, HRM and Bike Computer
    Last Post: 07-29-2012, 05:09 PM
  2. Black Magic; Tips and Tricks
    By leshaghal in forum All Mountain
    Last Post: 07-20-2011, 01:21 PM
  3. Tips and tricks for mountain biking?
    By ManianMTB in forum All Mountain
    Last Post: 07-12-2011, 03:24 PM
  4. Sustained Climbing or Climbing Repeats? What to do.
    By vetprowanab in forum XC Racing and Training
    Last Post: 06-18-2011, 11:06 AM
  5. Angleset Tips & Tricks for a V10?
    By IntenseMack10 in forum Santa Cruz
    Last Post: 04-27-2011, 02:23 PM
