Results 1 to 13 of 13
    newbie boobie.
    Reputation: donkekus's Avatar
    Oct 2002
    Ti Rigid Fork...
    Does anyone make a Ti rigid that looks more like a cyclocross fork? I mean, I have a Pace RC31 and I don't particularly like the way it looks on my new Ti frame and am thinking of getting a Ti rigid. However, if my only choices are the segemented forks that I see everywhere then I will just stick with the Pace.
    Oh, and it should be disc. (no studs either).
    TIA.
    It ain't easy being human.
    Kill your... television
    Reputation: motoman711's Avatar
    Quote Originally Posted by donkekus
    TIA.
    Have Jeff Jones build you one of his truss forks. It'll run ya about 1K.
    newbie boobie.
    Oct 2002
    Quote Originally Posted by motoman711
    I want simple lines. In a dream world, it would be a ti version of a Type II, disc only.
    kellyme
    Reputation: larutaviking's Avatar
    Morati makes Ti-forks for you.
    Check out Morati's Ti-forks they are beautiful and expensive.
    www.morati.com
    Put me back on my bike!
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    Tell you what - I'll give you $25 for that ugly Pace fork to offset the cost of your new Ti fork....lol..... Yeah right....
    Isn't the Morati one that looks more traditional (non-segment) the road version?
    I'm thinking you're going to have to go full custom (unfortunately).
    FF
    "If I'm leading, I'm bleeding."
    newbie boobie.
    Oct 2002
    $25? I was going to sell it for $20...
    AFAIK, the Morati is just like all the others though the legs are sliced and tapered near the axle.
    Dang, full custom = $$$ x1,000,000.
    Reputation: brant's Avatar
    Forks are constant diameter for a reason. The larger lower leg (compared to a tapered fork) help a lot with torsional (steering) stiffness, and feel under braking.
    With ti being much more flexible than steel, you need to keep some stiffness there.
    Reputation: itsdoable's Avatar
    Magmaa makes very nice unicrown taper leg disc only forks for MTB, Cross & Road (which by the way are stiffer than many constant diameter forks I've used!).
    <img src="http://www.magmaa.com/images/mtb-forkdisc.jpg">
    What constant diameter forks that you've used that are more noodly than that unicrown pictured above?
    newbie boobie.
    Oct 2002
    Quote Originally Posted by itsdoable
    Any idea on cost, wait, weight, etc? THX.
    Quote Originally Posted by brant@on-one.co.uk
    I have 2 XACD forks (disc & V), and 2 Magmaa forks (mtb disc & road), and the Magmaa's are both noticably "stiffer" in that they do not have as much for and aft flex. I don't notice much difference in steering precision in practical use. I was surprised by the anorexic look the Magmaas, but they do perform well (in the flex department), even compared to many steel forks I have (P2-TB, P2, Vicious, Dimension, Spicer, tange, syncros, etc...) - it's comparable to the P2-TB fork.
    Cheers,
    Tom
    They list the fork at 315 euros, disc and custom crown-axle disctances may be extra. It was a little less back when I bought it, but the exchange rate was different too.... They list it at 535gm. www.magmaa.com
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Why not contact XACD? They might be able to do it for you. Although, its Chinese new year now so theyre on vacation. But my forks ship out this month .
    Herro prease
  1. Ti rigid fork
    By patirwin in forum 29er Bikes
    Last Post: 06-11-2004, 01:19 PM
  2. rigid fork tire clearance question
    By bobde in forum 29er Bikes
    Last Post: 04-26-2004, 06:25 AM
  3. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
  4. Airborne's Ti rigid fork, 26" and 29"
    By weather in forum Airborne
    Last Post: 02-27-2004, 12:06 AM
