Therapy Components/ Brake Therapy
Anyone use one of these? I have seen some other threads, but they're years old. I can't believe they run $150, but I'm hoping to convert my old retro rig to disc and I think the A2Z adapter might jack up the frame.
Thoughts? Anyone with a TC one to sell?
http://2btherapy.com/index.php/bikes...conversion-kit
the A2Z adapters work on bikes with large flat droputs like GT bikes ... Therapy Components makes a good product but its so spendy ... check out these adapters as a more affordable alternative
 Originally Posted by mikesee
Better suited to non-aggressive 125# gals named Russell.
Take this with a grain of salt (since it may come down to how you ride/brake), but TC-type adaptor apply twisting rotational (inward) force on your seat stays if your canti/vee bosses are welded off centered - and most are, because canti/vee bosses are designed to be used as a pair, not just one side. So this rotational force may rip the boss out of the seat stays with TC-type adaptors. I saw a few pictures did just that using brake therapy type adaptors. A big gaping hole on the seat stays.
I use A2Z on my GT and it works perfectly. Drop outs are designed to take rotational forces and square hits, I think it would be more suited to host a brake adaptor. But then again like Zoke2 says, A2Z adaptor works only on big flat dropouts (like GT) as it is designed to sandwich a dropout with plates.
What kind of frame are you working with? If its an older Trek, Fisher or Klein, check this out: http://cgi.ebay.com/Trek-Klein-Gary-...item3a5855732e
Ive got one on my bike, works extremely well, looks factory.
Thanks- it's a 93 Tange Prestige Paramount Series 70- no big, flat dropouts, but no hood or anything either. I don't have a close-up. Thinking about having an IS mount welded on for about $100...
- You may not post replies
- You may not edit your posts
Forum Rules
