Results 1 to 17 of 17
Thread: tenniss elbow
    Sep 2004
    tenniss elbow
    Anyone get tennis elbow related to riding SS? I mean, from pulling up on bars while grinding out steep climbs? Perhaps transitioning to a swept bar like a Jones Loop bar or similar will help?
    I'm currently running a 7 deg sweep riser bar. Thought the pain in my elbow was from riding rigid so I put a Reba on there, helped a little but the tendonitis is back with a vengeance after riding some tight, twisty trails with lots of short steep climbs that had me wrastling the bar. Maybe I shouldn't do that (?).
    Thoughts????
    Aug 2010
    SS rigid here with similar occasional issues.
    Stateline Falls, Watauga
    Reputation: JeffL's Avatar
    Jan 2009
    Same problem here. I've even had surgery to relieve the pain from lateral epicondylitis, which helped for about a year but the pain still comes back if I don't do the proper exercises. I ride SS rigid, but I'm not sure if my cycling or paddling is the real cause. This device and associated exercises helps alot. More than surgical relief, in fact...
    Amazon.com: Thera-Band Flexbar Hand Exerciser - Tennis Elbow Relief Bar: Health & Personal Care
    It never gets easier, you just go faster. -Greg LeMond
    I'm not as fast as I think I am. -JeffL
    I'm your density
    Reputation: random walk's Avatar
    I had a bad case of it when I started SSing (also rigid). I installed some Ergon GC2 grips; between that and consciously relaxing my death grip on climbs, it eventually went away.
    "Those skilled at the unorthodox are infinite as heaven and earth, inexhaustible as the great rivers."
    — Tzun Tzu
    No known cure
    Reputation: Vader's Avatar
    I only have issues in one elbow. Maybe it's from something else.
    Ripping trails and tipping ales
    Jan 2009
    All my trouble has always been in only one elbow. And Ergons don't help - I've used Ergons for over 5 years and they help greatly with wrist issues. But only the Theraband exerciser I linked above helps me with the tennis elbow pain.
    Sep 2004
    Some of the guys I ride with use Jones bars or Mary bars or similar and swear by them, primarily for the control they feel while riding through technical singletrack. And these guys get vertical a lot, frequently unweighting the front, wheelies, manuals, etc.
    When I put my hands out and simulate a rowing motion, it feels much more comfortable with the hands rotated at an angle simulating greater sweep. But when I simulate my preferred position for downhill, then I'm looking for much less sweep. This is why I abandoned the Carnegie bars (24 deg sweep) in the past - they felt "OK" for cruising around, pretty good for tight/twisty technical singletrack, but not good for fast downhills. Maybe I just didn't give them enough time to get used to it.
    try rotating your bars back so they sweep back but also down a little. makes all the difference for me. never liked the ergons.
    Quote Originally Posted by BmoreKen View Post
    I get this issue sometimes. Do you use bar ends? From reading your posts it doesn't sound like you do. I found that using bar ends felt good but killed my elbows. I have used all forms of swept bars, but I have gone back to more of a traditional wide bar.
    I have not tried rotating them down at all like the previous post ^.
    i have this also on my left elbow. i ride a rigid 29er
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by saki View Post
    Tendonitis in the elbow - main cause, poor shoulder function.
    The 14 warmest years have all occurred in the 16 years since 1997.
    Reputation: Flat Ark's Avatar
    I get elbow pain if I use a widish bar. One with 10 or more degrees of sweep makes it worse. A narrow flat bar (FSA SL-K) with bar ends alleviated the issue for me. A wide bar makes me flare out my elbows which also was causing some neck/shoulder stiffness. The FSA bar causes me to keep my elbows tucked and my upper body (neck/shoulders) relaxed through the rough stuff.
    Reputation: Charlie Cheswick's Avatar
    Tennis Elbow
    I had it bad when I first started SSing, especially in my left elbow. My remedy was bar ends. It may sound crazy but just turning your grip 90 degrees takes a lot of the strain off your elbow and allows your biceps to pull in more of a straight line. I now do all my climbing on the bar ends and no more pain.
    wow thanks bruce i thougt it was old age
    Moderator Moderator
    Theraband bar will fix it right up
    I have had numerous bouts of elbow tendonitis going back more than 10 years from when I was a serious rock climber, and I tried *everything* - acupuncture, diet, new grips/positions on the bike, ibuprofen, etc. I knew surgical outcomes are mediocre at best (and I didn't have the $ anyway) but then I read this:
    Phys Ed: An Easy Fix for Tennis Elbow? - NYTimes.com
    Note that the researchers actually had to *stop the study* because the bar/exercise was working so well that it would have been unethical to continue making the placebo/PT group continue.
    And no, it's not a scam. The exercise is easy to learn (even if you're a spaz like me) and the bar costs like $15. Nothing else to buy. Do it 5 times a day for 10-20 reps on each arm and I pretty much guarantee you'll be good to go in a couple of weeks.
    Amazon.com: Thera-Band Flexbar Hand Exerciser - Tennis Elbow Relief Bar: Sports & Outdoors
    -Walt
    Waltworks Custom Bicycles
    Salt Lake City, UT USA
    www.waltworks.com
    waltworks.blogspot.com
    hey walt thanks 15 bucks and looks way more convenient thanks
    Dec 2012
    yes as nuts as it sounds, mounted bar end inside the grips about 16" apart, reason being changing hand positions seems to help me a ton, maybe bar end could provide the same relief but i like the lowered position.
Hot Deals
Contests
Latest Mountain Bike Articles
