Page 1 of 2 12 LastLast
Results 1 to 25 of 38
    Reputation: sprocket47's Avatar
    Oct 2010
    Swapping cogs made easy
    After being introduced to a new cog technology on a previous thread, I decided to give the "quick-cog" by Lunar Bikes a chance.
    The design is very solid with high quality manufacturing. I purchased this with 2 optional cogs that attach to the base. Changing them is very easy by simply removing a securing ring. I'm impressed with this product so I figured I would share.
    I recently moved to a new area and I'm working on finding the best gear for the various rides. Also, as in most places, the terrain is vastly different from one trail to another so I can gear appropriately prior to heading to a certain location in only a minute.
    For the record: I paid, my own hard earned money, for the quick-cog and I have no affiliation with Lunar Bike whatsoever. I'm just excited about this new product and wanted to let y'all know.
    Reputation: A1an's Avatar
    Thanks for the initial review. Look forward to see some follow up after prolonged use.
    Signature
    Reputation: trrubicon06's Avatar
    No experience with those, but I do with Gear Clamp. I find these very easy for adjusting chainline and swapping standard cogs.
    Oct 2012
    I have been using g clamp as above for the last 2 months. Very easy to change gearing and achieve perfect chainline. Only need allen keys to change, no need for a chain whip.I would recommend this product.
    one chain loop
    Reputation: fishcreek's Avatar
    that lunar cog looks cool. is there a play between the base and cog interface?
    everything sucks but my vacuum cleaner.
    Tool?
    Quote Originally Posted by sprocket47 View Post
    Does this require a special tool or something I would ordinarily carry on my rides?
    GearClamp rocks if you're using a traditional SS tensioning method (ebb, track ends...), but I've had issues when running a tensioner
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Quote Originally Posted by memine View Post
    I looked into this a while ago and according to the site the cog can be swapped without special tools. IIRC anything pointy will do, like a knife blade, flat screwdriver or similar.
    I'm very tempted to get this Lunar cog. Mostly I just ride 34/20 and don't worry about speed, but I have the feeling I'm missing out on something and can't be arsed to buy a 19t cog and change it. The chainwhip and lockring tool are a turn-off for me, I like to avoid touching them.
    The gear clamp looks like a brilliant innovation as well.
    May 2005
    Is it really that hard to brake out a chain whip, and switch a cog, what is it, 3 to 4 minutes tops.
    Mar 2011
    Quote Originally Posted by OneBadWagon View Post
    What kind of issues have you into? I would have been interested in trying the gearclamp out.
    Bikes, lots'o bikes
    Quote Originally Posted by joshhan View Post
    When using a sprung tensioner, I was getting abnormal skipping, seemingly because with the Gear Clamp there is no compression on the cog stack, there is a tiny amount of play. Using a lock ring, the cog is under pressure and will remain straight on the hub, but with the gear clamp there is a tiny amount of play that ended up being enough to allow skipping with a tensioner.
    That being said, I have two Gear Clamps and find them to be a killer product and continue to use them.
    Oct 2012
    Quote Originally Posted by Oliver View Post
    Now that I started thinking about it, it really isn't such a big fuss. Maybe I should keep the chain whip and lock ring tool more easily available so I'd be out of excuses.
    human dehumidifer
    Reputation: wv_bob's Avatar
    I wondered how you'd know you had the play out of the cog setup using that system. I guess you just push it over tighten it up and hope for the best?
    If in doubt, assume sarcasm
    Canfield Nimble 9 * WTB Phoenix * Salsa Big Mama
    one chain loop
    Quote Originally Posted by wv_bob View Post
    preload it with spacers and regular lockring then tighten the clamp.
    not really sold with this design.
    undercover brother
    Reputation: tangaroo's Avatar
    Quote Originally Posted by fishcreek View Post
    But then I don't really see the benefit. You still have to use a lock ring tool and chain whip and it seems like more work in the end. To me, spacers and the right tools are quick and easy enough. Plus, I like the look of the spacers on the freewheel. It takes me less than 2 minutes to change out cogs.
    I would follow you into the mists of Avalon if that's what you mean.
    If all else fails, I blame it on my tiny wheel size
    Oct 2010
    There aren't any special tools needed and there isn't any play at all between the cog and the base. It's manufactured very tight and solid. I like the feeling of swapping it out without using the other tools and what I feel can turn out to be wear and tear on the freewheel body. The lock ring/spring, or whatever it's called, can be pulled off using a thumbnail.
    Reputation: itsdoable's Avatar
    I'd be curiuos to see if the cog indents the aluminium carrier over time, especially those running low ratios with a large cog. Was planning on trying one, but shipping here is a bit steep ... have to get a few more people interested first.
    Quote Originally Posted by trrubicon06 View Post
    This is an ugly solution to a problem that doesn't even exist.
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    Quote Originally Posted by SS Hack View Post
    Ugly doesn't mean its not effective!
    I have used gear clamps along with the same make cogs (Niner) with great success. Since all the Niner Cogalicious cogs are the same width..no adjustment needed except for the slider. No cassette tool or chainwhip needed to remove or swap...Just 3mm allen wrench. They are also very light and inexpensive ($20).
    I however, know exactly which cog I need for where I ride or have been riding..so I use regular spacers because it does look cleaner and goes with the other gold on my bike. If I do travel, and do need to swap cogs, I put the clamps back on!
    Sprocket47- sorry for the thread steal, but GearClamps are another great solution.
    ..and no I don't work for them, nor do I receive any promotions from the company.
    Santa Cruz Tallboy carbon
    Lynskey Pro29 SL SS
    Cervelo S2 Ultegra
    Salsa Selma
    Ride Responsibly
    Reputation: LWright's Avatar
    Here you go; http://pardo.net/bike/pic/fail-029/index.html
    Although if you need more than one rear cog why not just go 1x9?
    Quote Originally Posted by dubdryver View Post
    I also can't imagine trying to take those things off when they're all caked with mud.
    one chain loop
    that clamp will be less ugly if they did the bolts like what you see on lock-on grips. still not buying though.
    Unless you want to be able to change cogs with a multi-tool...
    Although the cogs are very easy to change, that was not the primary goal of the design. In fact the 1st prototype was a 3-piece design with the cog in the center and the cassette had to be dissembled to change the cog.
    The primary goal was to make a low cost cog out of the highest quality material and manufacturing processes available. By using a two piece design, there is not much wasted material and machine time as you would get trying to machine it from one solid part. We are able to sell what is probably the highest quality cog out there for only $25; it would have cost 4-5 times that if it was machined from single piece. Also the cassette spline of any cog usually has no wear compared to the teeth, so paying for that to be machined every time you buy a new cog is a waste. Our driver can be reused with other cog sizes so there is no waste.
    We have tested this design for the past nine months with heavy strong riders and so far not even a hint of any wear on the cog teeth or spline interface. The deep, large diameter spline interface has so much surface area that the load in pounds/sq.in is very low and will not cause any displacement or wear of the material.
    Quote Originally Posted by TacoMan View Post
    Thanks for the background. The additional context really highlights the creativity and innovation that was applied to the product.
Hot Deals
Contests
Latest Mountain Bike Articles
