Results 1 to 14 of 14
    wish I was out riding
    Nov 2012
    Surly chainrings
    are they 1/8 or 3/32?
    I have a 36t*104 ring, paired with a 14t cog (this one is 3/32) and a sram pc1 chain.
    Occasionally I hear cracking noises so I'm trying to understand where it's coming from.
    chain tension is OK, so is chainline..
    if, as I suspect, the rings are 3/32, then I'll probably ditch the chain for a new one.
    call me paranoid, but I don't want to break a chain while off the saddle on a climb...
    thanks!
    Jan 2009
    those rings should be 3/32" but a 1/8" should not cause problems like that. how many miles are on that chain? what kind of cog are you using? 36/14 is a STEEP gear. are you riding that off-road?
    Nov 2012
    surly cogs. how many miles on that chain... let me think. 4-500?
    and no, 36*14 is just for commuting/road. As soon as I put on mtb tires I will switch to a 34*18 or even 20!
    im not using surly rings but do here the same cracking in my chain sometimes.......i think its the tensioner but havent had time to change it.
    Southern Afghanistan
    Supervisor
    Fred and Barney know how to kill HOOHAs
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    I believe you can get Surly cogs and rings in either 1/8 or 3/32. But chain/chainring/cog size shouldn't be an issue -- I have a 3/32" cog and chainring with a 1/8" chain and it works just fine.
    When do these cracking sounds occur? Where does it sound like they're emanating from? How often do they occur? Noises on a bike are incredibly hard to pinpoint because the frame and all other hollow parts tend to act as amplifiers.
    Sometimes, I question the value of my content.
    Nov 2012
    thanks for your reply. the cracking sounds started when I changed my drivetrain (new cogs, rings and chain) and occur when I start pedaling again after some coasting. I am fairly certain that it's the drivetrain as they were more common before I tensioned the chain a bit.
    just to clarify: chainline is OK, so is tension, and I cleaned/lubed recently.
    SSolo, on your left!
    Quote Originally Posted by BuntyMan View Post
    I've run Surly 32T chainring and 20 cog with KMC K810SL-CP KMC USA 1/2x3/32" chain, never any noise.
    I grease my chainring bolts and tighten nice and tight.
    Get off the couch and ride!
    Oct 2007
    What hubs are you using? I had hope pros and I kept getting a cracking sound which i thought was my chain but turned out to be 2 cracked pawl springs which was an easy fix.
    Nov 2012
    oh bollox..... yes, hope pro2 singlespeed.....
    might be an easy fix, but not exactly "cheap" I fear.....
    Oct 2007
    Re: Surly chainrings
    Its cost me like 7bucks. If you call hopes us distribution they can send you the parts. The fix is simple too. Pull the end cap and the free hub pulls right off. Took me a few minutes to fix.
    Sent from my Galaxy Nexus using Tapatalk 2
    Nov 2012
    that's inspirational. thank you I shall have a look at some stage this coming weekend, hopefully! thank you
    Oct 2007
    sorry didnt realize you were in the UK. You should have a lot easier time than I did finding parts. Its really easy. basically 2 more steps than changing your cog.
    Nov 2012
    yeah I googled a bit and it looks like it's doable... at least inspecting it to check if everything is OK.
    Thank you so much for the suggestion!
    Nov 2012
    Quote Originally Posted by BigE610 View Post
    you have a beer on me.
    I managed to open the hub, and as you predicted I had not one, not two, but three pawl springs missing!
    Ordered the parts..... thanks for the hint, could have been a bad day on the road!
  1. Why 10-speed chainrings sell at much higher than 9-speed chainrings
    By solitone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2014, 05:49 PM
  2. Paid SPAM: Surly Black Floyd with Surly tubes
    By tracerprix in forum Fat bikes
    Last Post: 11-15-2012, 09:02 PM
  3. Replies: 1
    Last Post: 10-08-2012, 01:26 PM
  4. Which fork? Surly Instigator VS Surly Troll
    By Bokchoicowboy in forum General Discussion
    Last Post: 09-02-2011, 08:21 PM
  5. Replies: 0
    Last Post: 01-21-2011, 08:17 AM
