Results 1 to 5 of 5
    Aug 2010
    Surly chainline calculator for 142 X 12?
    Setting up a 2014 Nimble 9 SS.
    I've always used the Surly calculator but don't see specs for 142 x 12.
    Can I use it? Did I miss it?
    May 2005
    I've never heard of this calculator, where is it and what's it for?
    I usually set my chainline by measuring the distance from the center of the seat tube to the center of the chainring and then figuring out where the rear cog needs to go to match. So if the chainring is 56mm from the center of the seat tube, the cog needs to be 135/2 - 56 = 11.5mm from the inside of the right drop out. That's for a 135mm QR hub. For a 142mm hub it would be 142/2 - 56= 15mm.
    Pretty easy if you can do basic math and can measure stuff. I know that's asking a lot for some people.
    Aug 2010
    I run the 2014 12x142 dropouts on my 2013 N9 (originally 10x135). Chainline stayed the same, just use the 10x135 stuff. I use the same spacers.
    "You can't drink all day if you don't start in the morning." ShakyPuddin
    Aug 2010
    Quote Originally Posted by swildnm View Post
    I figured this out after posting...
  1. spoke calculator?
    By Action1 in forum Wheels and Tires
    Last Post: 10-21-2013, 06:35 PM
  2. Surly Mr Whirly singlespeed chainline?
    By lolmaus in forum Surly
    Last Post: 01-18-2013, 10:12 PM
  3. Suspension Calculator
    By Orb-12 in forum Shocks and Suspension
    Last Post: 12-07-2012, 06:14 PM
  4. Yet another gear calculator...
    By tdhood in forum Singlespeed
    Last Post: 06-22-2011, 01:10 PM
  5. Replies: 3
    Last Post: 03-10-2011, 05:38 AM
