I bought a set of race face turbine cranks isis and a blackspire monoveloce chainrings for my SS build. These are what people seemed to recommend. What is the proper way to bolt the ring to the crank? Should it sit on top of the cranks, if so the arm makes contact with the ring, which prevents it from sitting flush. Does it go behind the crank and if so, I guess I need to use shorter bolts to hold it snug or some sort of bash ring on top? What additional parts needed?
Here is a picture of what I am talking about:
It looks like the chainring was cut so as to sit on top of the crank arm spindle, but the arm rubs in the back which prevents the ring from sitting completely flush. If I run it underneath, what parts are needed and where should i get them?
