Results 1 to 6 of 6
    Jun 2010
    Steel fork for 15mm thru axle
    I'm looking to put a steel fork on my Spot Rocker. All of the steel options I've seen online for a thru axle are for 20mm. Anyone know of other options corrected for a 100mm fork they'd recommend (aside from custom)?
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    I'm looking for about the same.. chromoly fork, 28.6|30 threadless steerer, 26" wheel, 440-445 mm ATC, 15 mm Maxle.
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
    You're probably going to have to go custom. I haven't seen anything either.
    Reputation: rob1035's Avatar
    Salsa has a 15mm steel fork with a tapered steerer on the El Mariachi SS, but I don't know if it's available separately. Soul Cycles has one in development but I have no clue when or if it will be available...
    meow, meow.
    Salsa have CroMoto Grande for 29" only I think.
    Salsa is going to be releasing the cromoto grande with 15mm TA around the end of March. I actually emailed them asking if they were going to offer it aftermarket.
  1. Whiskey #9 15mm Thru-Axle fork?
    By OldHouseMan in forum Cyclocross
    Last Post: 10-18-2014, 07:46 PM
  2. Convert 9mm QR fork to 15mm Thru Axle
    By Koin in forum Shocks and Suspension
    Last Post: 05-21-2014, 07:14 PM
  3. 15mm TA on rigid steel fork?
    By bsieb in forum Frame Building
    Last Post: 08-04-2012, 05:23 PM
  4. 15mm thru axle fork adapter
    By jeronimus in forum Cars and Bike Racks
    Last Post: 11-21-2011, 07:31 PM
  5. Steel Fork with 15mm QR?
    By arashi in forum Singlespeed
    Last Post: 01-25-2011, 02:21 PM
