    ~ B A D A S S ~
    Reputation: car bone's Avatar
    Steel 40/41t rings without ramps/pins? Or worst case Alu
    So i have an 8sp setup, 8sp spacing, cogs and chains and such and now i'm kinda looking for either a steel 5bolt ring in 40/41t size for that drivetrain. Or get a 4bolt crank and a steel 40/41t chainring for that one. I don't want 11/10/9sp stuff i want thicker stock made for 8sp chains. Preferably 5bolt since I have a 5 bolt cranks. and if thats not possible i have to get a 4bolt crank.
    What do you guys recommend? Before I had a 36t shimano 9sp ring up front and while that was nice I'm now stepping up the game.
    And this time i want no ramps and pins (and 8sp compatible/optimal).
    What about alu? Its for my commuter so I prefer to buy the longest lasting stuff out there, if possible.
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    1*14*29*2.1 & 1*1*29*2.4
    depending on your BCD you could see if middleburn make one..it'll be alloy though. I use their standard ring which has no ramps or pins. some cranks are hard to find stuff for, so you need to work out your bcd
    ~ B A D A S S ~
    I have the standard road triple one, non compact,non double, i think its 5x130. However I'm not 100% sure it will work out on my frame yet. its a dura ace triple.
    ~ B A D A S S ~
    Yeah btw I'm pretty confident i can find whatever in alu, its very common, but steel, as good as or better durability than shimnao steel rings?
  1. Has anyone used a road triple on a mtb? Also, big steel rings, 104bcd?
    By car bone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2013, 05:23 AM
  2. Steel single rings?
    By Noclutch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-09-2011, 06:05 PM
  3. Anyone have light steel 2x10 granny rings?
    By gticlay in forum Shimano
    Last Post: 09-11-2011, 01:52 PM
  4. Recommendation for 9-Speed chain with Chainrings without Shift Ramps and Pins ...
    By mtbvfr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2011, 11:07 AM
  5. Chainring with no shift ramps and pins
    By p0r0y in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2011, 04:20 PM
