Stans Arch Vs 355 ?
Building a new SIR9 (2009 root beer !!! )
The bike will be used for all around riding, nothing too aggressive but will include some rocky single-tracks.
I am building my wheels with XT hubs and Stans rims. I debate between the 355 and the Arch. Will the 355 be too flex?
Any advice?
Are you used to light rims or bigger rims?
How much do you weigh?
Are you a smooth rider or an aggressive rider?
I think the answer depends on those questions and maybe more
I run the Arch on my RIP, the 355 on my MCR and 355 on my rigid singlespeed. No issues with any set. The MCR has about 2000 miles on the rims - no hops and true as the day they were built. I am not a rider that is hard on rims. 170lbs and slow on the downhills. A friend runs the 355 on his super lightweight CC bike and was complaining about the durabilty. He rips the downhills and is hard on parts.
Both are great rims! Make sure you get a really good wheel builder.
my old wheels where Duster on XT - I guess this is a medium weight set.
I weight 165lb and my riding is not aggressive.
I don't have a comparative experience to share here just a few observations.
I just put a set of Stan's Arches on my Sir9, my rationale was durability. I can't afford to replace them anytime soon and AZ trails can be rough on a wheelset. Not much of a weight penalty either. They feel nice and stiff, haven't noticed any obvious flex yet but only a couple of rides on 'em (I'm 175 geared up and ride a bit more on the aggressive side).
If you're running front suspension you could mix it up with a 355 up front, Arch rear.
It's a nice dilemma to have and I don't think you can go wrong either way. Have fun with it.
Cheers,
M
It isn't about flex. What's your weight and riding style? If you're 160lbs+ or if you're hard on wheels, go with the Arch. If you are a total weight wienie and don't weigh much, get the 355. I'm 185lbs and ride a Flow and I've knocked the rear out of true. Next wheelset will be a 36 hole flow on the rear instead of 32.
there is not any spoke/rim flex it's the tires. That stated, if you weigh below 170 you can go 355's front and rear. I weigh 192 and went with a 355 in the the front and the arch in the rear, the rim profile is the same. If you weigh 175 up my advice would be to go with an Arch in the rear 32 or 36 spokes.
Boyeeee
I don't see any 26", 36 hole rims on the site. Some 36 hole flows would be interesting.
- You may not post replies
- You may not edit your posts
Forum Rules
